Honda Fit Tearing Up The Track @ "el Tuque" In Ponce, Pr
Old Nov 4, 2009 | 07:53 AM
  #41
carlosalicea's Avatar
Oye tipo..... que ha pasado!!!!!
la mia sigue cojiendo paleta ( pa que no se rompa) 96,000 millas y sigue igualita (bueno, mas piedritas en el bonete y bumper, y un millón de insectos obligao!!!!) pero chacho esta mierda de carro es buena con cojones!!!!!!!!!!!!!!
saludos
Old Nov 4, 2009 | 10:46 AM
  #42
Vanishing Point's Avatar
Be careful with those VictoRacers, you need to shave those tires per the manufacturers recommendation for dry track use.
Important Notice: Kumho VictoRacer V700 tires must be shaved to 3/32" - 4/32" of remaining tread depth for any track use in dry conditions.
Kumho advises that the VictoRacer V700 DOT-legal competition radial must be shaved prior to use in dry track conditions. If this tire is not shaved, excessive wear may occur causing the tire to wear to the cords prematurely in a localized area.
Tire heat cycling will not prevent the excessive localized wear of full tread depth tires but will continue to enhance the tire consistency and wear on shaved tires.
The VictoRacer V700 should only be used at full tread depth (6/32") on the track in wet conditions.
Old Jan 16, 2010 | 03:04 PM
  #43
FitFlowjoe's Avatar
This GD3 died 12/20/09 @ about 4:30am... Very sad, but it gone to a better place now.
Old Nov 26, 2011 | 12:07 PM
  #44
nttdemented's Avatar
I has been reincarnated now cuz!
But like a newborn baby Jesus, it's not her time yet.
Rabee
May 31, 2014 03:35 PM
Terry M.
Apr 9, 2014 09:50 PM
Amageus
Feb 7, 2008 06:36 PM
kennef
Car Shows, Events, and Racing
13
Nov 19, 2007 02:57 AM
Bounty Hunter
26
Jun 9, 2006 05:26 PM
