Jazz CVT to Fit Auto, Possible?
Old Nov 7, 2009 | 01:49 AM
Master_Scythe's Avatar
I drive city a LOT so as such am going for the CVT jazz (older model).
However im worried about its reliability.
After a lot of research it seems its pretty fault free. Every complaint on the JAZZ was before HONDA AUSTRALIA got the CVT fluid in, so everyone was using Z1 (took a few years for them to import it).
But just in case, I was wondering if the Auto gearbox found on the USA FIT is able to be direct swapped for the UK\AUS JAZZ CVT?
I know manual is a LOT of work to swap over, so how about this? mainly curious is all.
Old Nov 7, 2009 | 07:31 AM
Type 100's Avatar
It might be just as big a headache as swapping your CVT for a self-shifter. You'll probably need a new ECU for the torque-converter A/T.
Only real "saving" I can find is that you don't have to swap pedal assemblies, but I could still be wrong. The US Fits have drive-by-wire throttles - do you have the same type in Australia or do you have good old cable-actuated throttles like ours?
Old Nov 7, 2009 | 07:34 AM
cable.
yeah it may be hard....
chiu
Jul 31, 2008 09:34 AM
kenken
Apr 10, 2008 11:16 PM
JazzEr
Mar 5, 2006 12:48 PM
shaolin
Oct 23, 2005 11:35 AM
