How to get codes and clear TPMS light?
Old 01-04-2010, 11:45 AM
CptanPanic's Avatar
My TPMS light went on, but my code reader (Scanguage) doesn't detect any codes. Will only the honda scanner read those codes?
Thanks,
CP
Old 01-04-2010, 05:13 PM
i think you physically need the TPMS RF modules in order to 'clear' the codes.
during the winter my GE has TPMS come on due to snow tire set i have without the TPMS modules...and in the spring when i put the stockers back on the TPMS light goes away automatically.
Old 06-08-2010, 10:20 AM
glen62's Avatar
Thumbs up Well, I had the same lamp
Thanks,
CP
I still have in front of me the bill, just 3 days ago, $137 bugs. Could be TPMS receiver or any of the 4 for sensor in your tires, mine was tire #3
DIAGNOSE CODE 35-1 tire 3 SENSOR LOW VOLTAGE
SOLVED "REPLACE SENSOR AND RELEARNED SYSTEM"
If you are a lucky boy check your TPMS fuse,if not, you already Know
Old 07-28-2010, 04:10 PM
xxnick9oo2xx's Avatar
i have a 2010 honda fit sport. while i was doing the paper work they were cleaning it and im assuming they put air in the tires without checking the psi. an hour after i was home the light came on "TPMS" this morning i went out there with a tire gauge and all the tires were well over 33 psi so i let some air out and drove it maybe 1/2 a mile and the light came off. The light will come on if too much air is in the tires
canuck901
11-13-2017 08:07 AM
bargainguy
12-05-2014 10:05 PM
corygibson
05-23-2013 09:15 PM
smetzger
09-10-2012 11:48 PM
Brain Champagne
05-14-2011 01:51 PM
Quick Reply: How to get codes and clear TPMS light?
