Anyone Purchase an HID kit for Sport Fogs?? Warning Inside...
Old Aug 18, 2006 | 10:03 PM
Steaksauce's Avatar
Yah, I did purchase a kit, what was called "plug and play," but they're an independent company hailing overseas... so it wasn't true plug/play, since the power supply cords are fitted with only electrical tabs and not with the plug to tap back into the electrical cable that supplied the original H11 bulbs. grrr...
But listen, all, if you are considering the switch to HID bulbs, you must consider looking for an HID bulb that has a cap to block front light from being thrown (the same kind of reason why the H11 bulbs have an opaque cap on them). As I fitted the HID bulbs into the lens housing, I realized that HID light will blow directly out from the fog lamp housing. Although I have yet to completely install the HID's (buy a yellow bulb instead of regular colors), I can see that glare will more than likely be a problem with HID foglamps since the Honda fogs don't have a cap to block light glare from oncoming traffic.
There is a metal tab that blocks light inside the housing. Problem: the tab is installed before the lens was sealed by glue. So be forewarned. If you get em instead, you'll see what I mean.
Old Aug 19, 2006 | 12:32 AM
aziatiklover's Avatar
Master FitFreaker
thanks for the infos man
Old Aug 19, 2006 | 07:20 AM
Tomh's Avatar
Senior Member
I sorta thought there is a cap and it give a better cutoff then the H4 ring adapter i have for the headlamps, eh oh-well.
Old Aug 19, 2006 | 08:08 AM
Wave's Avatar
I have yellow HID's in my fog light locations.
Have yet to have a problem with anyone brighting me. They sit pretty low on the car so that could be why.
Old Aug 19, 2006 | 05:24 PM
Thornlt's Avatar
Having just bought a Fit Basic and wanting to sport it up a little Any suggestion on purchasing foglight and not looking around at ground effect kits(?) Any suggestions Other than I should have got the Sport version. I know I know
Old Aug 19, 2006 | 10:17 PM
Tomh's Avatar
Senior Member
Just get the OEM fogs from your dealer, they should be very able to get them for you.
madtodaimax
Feb 26, 2014 04:22 PM
phuccer
Nov 19, 2012 08:09 PM
eggyacid
Sep 8, 2011 06:10 PM
samwell
Jun 10, 2010 01:38 AM
SoccaBoi
Oct 18, 2007 10:49 AM
