43.8 mpg
Old Jun 6, 2008 | 01:51 PM
percy's Avatar
43.8 mpg
Boston to Albany and back on the Mass Pike with some in-city driving at each end. I tried a variety of techniques discussed on this board. Most importantly, I kept the speed down to 60-65. I got off the gas pedal whenever I could having learned that no fuel goes through the injectors when you're in gear with no throttle. I drafted some trucks here and there at a safe (1-2 second) distance. I tried some engine-off coasting on some of the bigger hills but I'm not sure it's something I'd want to make a habit of. I also had topped up my tires to a still-reasonable 36 psi cold inflation pressure.
Average over 2 fillups was 43.8 mpg. On one tank I had 230 miles on th OD before the fuel gauge hit the halfway point.
It's pretty remarkable how much your driving style can influence mileage.
Old Jun 6, 2008 | 03:00 PM
rpboy06's Avatar
My parents were helping me move this weeking and we averaged about 38 mpg. I had my car filled with stuff, probably equivalent to 550lbs including me of weight.
Old Jun 6, 2008 | 03:14 PM
Sid 6.7's Avatar
Why so serious?
Good to see another 40+mpg story. You might be able to eek out a little more if you fill the tires up to the sidewall rating, 40-45psi I think, depending on the tire. 45psi has made a difference for me at least.
Grinder12000
Sep 26, 2012 06:12 PM
dmy
May 11, 2011 06:12 PM
Alex T.
Nov 16, 2010 03:28 PM
NavyShooter
May 24, 2009 12:46 PM
Doc Holliday
Dec 20, 2007 01:10 PM
