64mm Throttle Body
Old Aug 28, 2008 | 12:39 PM
  #101
Sugarphreak's Avatar
Push My Button
That TB looks a lot different than ours; Orientation, Shape and how it hooks up are all different.
Also as far as I can tell there is no restritive plate between the TB and intake manifold. You had mentioned that before, maybe it was deleted by the WR manifold? Will have to take a look at a stock unit to confirm.
Going to take some measurements of it ID on the manifold and TB when I have mine apart to put in the Rev2 WR manifold. I don't think there will be a benifit other than throttle responce if they are the same size.
Old Aug 28, 2008 | 10:44 PM
  #102
kylerwho's Avatar
spoon fed
In the end it would be like drinking out of a beer bottle and a sobe bottle. your mouth can only take so much liquid but it would fill up quicker with the sobe bottle because of the greater volume. someone needs to check and see if the same throttle signals are being sent to the bmw tb and the honda tb.
  #103
Push My Button
In case anybody is wondering, the 64mm TB on the MDX & Odyssey is a bust as well.
  #104
kylerwho's Avatar
spoon fed
whats wrong with those?
Old Aug 28, 2008 | 11:06 PM
  #105
Push My Button
From what I understand, way to big physically.
Maybe it is just me, but when I tear out my old manifold I am expecting the TB & manifold dia's to be the same.
Old Aug 28, 2008 | 11:18 PM
  #106
kylerwho's Avatar
spoon fed
maybe you can custom fit a flange to your weapon r manifold to fix the odyssey tb? are water passages the same?
Old Aug 28, 2008 | 11:27 PM
  #107
Push My Button
maybe something to look into later on, was hoping for a cheap bang-for-buck mod though.
Old Aug 28, 2008 | 11:28 PM
  #108
kylerwho's Avatar
spoon fed
seems a little more complicated. would definately like to figure this out.
Old Aug 28, 2008 | 11:33 PM
  #109
Push My Button
^^^ agreed, I could have been much happier without the teaser this thread has created. Oh well, at least the overseas Jazz has a new option,
Manxman, any chance Claymore can send a comment beyond the ban-grave through you for this thread? Is this TB in the OP's similar at all to the JDM TB for the 1.5L?
Old Aug 28, 2008 | 11:39 PM
  #110
kylerwho's Avatar
spoon fed
maybe you could send your version 1 weapon r manifold and i would figure out a way to fab an adapter and then bolt on an odyssey tb?
Old Aug 28, 2008 | 11:50 PM
  #111
Push My Button
My Rev1 is due to be en-route to WR under a product exchange. You would be better off ordering a new one from them and then modifying it.
I think that Honda 64mm one might be too big in general to even consider installing. Maybe if you are near a dealer anytime soon have a look for yourself.
Old Aug 29, 2008 | 12:01 AM
  #112
kylerwho's Avatar
spoon fed
i dont really want to invest the money or i would.
Old Aug 29, 2008 | 12:11 AM
  #113
Push My Button
The S2000 has a larger 64mm DBW TB as well in the newest version. Checking out some pictures it doesn't look too crazy huge....
...lol, i am just grasping for straws right now.
Old Aug 29, 2008 | 01:37 AM
  #114
kylerwho's Avatar
spoon fed
if you can figure out which tb will work i could possibly fab something up to make it work with our oem manifold. seems like a spacer would work to connect the two. but would the l15 take advantage of the amounts of air it will be fed?
Old Aug 29, 2008 | 04:08 AM
  #115
Slimjimx701x's Avatar
Tagging
Sugerphreak, I'll be awaiting your findings. On a sidenote, I wonder how this is going to act when it's mated up with the controllers.
Old Aug 29, 2008 | 04:29 PM
  #116
ghostfit's Avatar
i don't understand the problem with the TB fitting. How hard is it for people to cut off the smaller flange and put on a bigger one that would allow for more clearance for the TB?
Old Aug 29, 2008 | 04:56 PM
  #117
kylerwho's Avatar
spoon fed
because the chamber that the tb is connected to is plastic. it is hard to cut off the flange and put a bigger one one. techically i can weld plastic but an aluminum space would be easier or a new flange on the weapon r manifold.
Old Aug 29, 2008 | 05:10 PM
  #118
Push My Button
Should have some measurements of everything by tommorow, basically if the diameters are the same then I am probably going to shy away from changing anything.
If I find out the manifold dia. is signifigantly larger then the TB, it will be off to "pick-your-part" to look for matching TB's to try out
I am thinking some TB's may also be larger in width and depth which won't let them physically fit into the space alloted.
Old Aug 29, 2008 | 05:13 PM
  #119
kylerwho's Avatar
spoon fed
i wonder about the s2k tb? what size? dbw?
Old Aug 29, 2008 | 05:20 PM
  #120
Push My Button
2006+ S2000's should have a DWB 64mm version. The pics I have seen of them look promising. Sounds like lots of owners don't like the DBW setup and swap them out for a cable version RSX-S throttle body, maybe that means there are some good deals to be had?
How sweet would that be if it uses the same voltage, bolt pattern and plugs.
