I Am Freaking Rubbing!
Old Feb 10, 2008 | 12:57 PM
jits14's Avatar
Like it was mentioned before, at that setup its all about what tires you use. I've ridden the same setup with two different tires, one rubbed sometimes and the other never rubbed once even with a full car.
205/45/16 at +38 on a flat summer tire setup with no beefy tread and you'll hear no rubbing. Anything with shallower shoulders.
Old Feb 10, 2008 | 01:00 PM
solbrothers's Avatar
that's what ive heard as well. i just hope my rims/tires go on with no problems lol.
Old Feb 10, 2008 | 01:04 PM
redrumm's Avatar
ive always had falken tires and they have smaller sidewalls. i had a 195/50-15 tire from kuhmo to falken and it was a difference in the sidewall
Old Feb 10, 2008 | 01:10 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Question... All of you talking about rubbing on NONE lowered cars. Is it rubbing all the time or once ever 5miles or so?
Honestly, if its barely rubbing suck it up and live with it. The rear will not hurt anything when rubbing. Its the fronts that wear out the fender linings and clips.
Old Feb 10, 2008 | 01:15 PM
fits_all's Avatar
do minor cutting in the rear and replace a inner feder clip which is in the front, and itll minimize something. it has been discused.
But, as someone said here, check where your problem is, then youll know what to do.
Old Feb 10, 2008 | 01:47 PM
Honda 2007 Fit SPC Performance Camber Kits
will this work for a camber kit? is that a good deal?
Old Feb 10, 2008 | 02:35 PM
fits_all's Avatar
u know how ur car will look with rear camber right?
Old Feb 10, 2008 | 10:46 PM
yeah it'll look retarded :P :P. i meant negative camber btw
Old Feb 11, 2008 | 12:12 AM
andyd's Avatar
someone sugested to me that i go to a 195/40/16 tire? Would this help?
Old Feb 11, 2008 | 12:18 AM
idk about if it'll fit on the fit, but that tiresize is less wide and less tall overall as compared to a 205 45 16
Old Feb 11, 2008 | 12:32 AM
andyd's Avatar
I am sure it will fit, a 205/45/16 is bigger....That and rolling the fender i am hopeing will fix the problem!
Old Feb 11, 2008 | 01:49 AM
  #32
Sugarphreak's Avatar
Push My Button
Originally Posted by FELIXY69
roll ur fenders
or run 195/45/16 i think 205 is too big
I agree with this solution, I had bad rubbing problems and going from 205's to 195's made all the difference for me.
Old Feb 11, 2008 | 02:17 AM
  #33
andyd's Avatar
Looks like I need to go to my tire shop tomorrow!
Old Feb 11, 2008 | 03:25 AM
  #34
koolkevin1107's Avatar
dude that's soo wierd! i'm running 16 x 7 konig heliums with a 40 offset wrapped in falken ze-912's in 205/45/16's dropped on tanabe gf210's and i do NOT rub in the back or the front. I can even have 3 passengers in the back for some serious wheel tucking and i still don't rub. I <3 my fit and it's 37mpg! =]
Old Feb 11, 2008 | 12:34 PM
  #35
andyd's Avatar
Went to a body shop today, they wanted 200 to roll the fenders....crazy.
Old Feb 11, 2008 | 12:36 PM
  #36
MarkyMark's Avatar
I don't think it's the fenders as much as it is the rear bumper mounting screw. I'm running 17x7 +40 and had to dremmel about 1/4" of it off.
Old Feb 11, 2008 | 02:11 PM
  #37
andyd's Avatar
I just saw that with closer inspection. I am going to try that.
Old Feb 11, 2008 | 02:33 PM
  #38
Amageus's Avatar
Originally Posted by lidoshorty02
wow i hav 17s lowered and it was so low i had 2 put spring spacers
What spacers are you using and where are you putting it? Any pictures? Im thinking of putting spacers in the rear cause I know for a fact they will rub. The wheel and tires on in my sig too. Im not lowered yet but will be soon. As of now I am not rubbing.
Old Feb 11, 2008 | 03:45 PM
  #39
andyd's Avatar
PROBLEM FIXED! It was the bolt!
Old Feb 25, 2008 | 01:59 AM
  #40
flipTEK 08 SSM's Avatar
pictures of that bolt that made the rubbing? i was planning on getting black slipstreams in 16's. planning to drop it with t1r's. pictures please. so do i need to roll the fenders or shave any part off from the back? help before i actually do any work!!!
