DIY disable A/C auto on when defrost selected
Old 01-29-2013, 12:01 PM
Dwalbert320's Avatar
With winter upon us I thought it would be alright to remind FFs that the A/C condenser cycles on when the temp selector is set to defrost. There used to be a nice DIY wich I used to disable mine. This allows me to decide if I want the A/C to be on or not when I select the defrost option.
Be aware that even if the green A/C light is not on the condenser cycles anyway in the defrost mode.....tricky tricky Honda!
Apart from using extra gas it also robs the engine of some go power especially when taking off from a complete stop.
The threads explaining how to do this are all there but the link with pics and instructions no longer works. ( FF search, google search etc to no avail).
Does anyone have a working link or pics they can post for this really useful mod?
As others have reported there is supposedly a way to disable this feature without disconnecting the plug using a series of knob selections but I can attest that this method does not work on GE8s.
Old 01-29-2013, 12:08 PM
FitStir's Avatar
Originally Posted by FitStir
That's the plug that has to be removed for the A/C to not come on automatically with defrost.
Old 07-03-2013, 02:27 PM
ck42's Avatar
Wanting to do this on my GE8. Same process? Things look the same?
Old 07-03-2013, 02:53 PM
FitStir's Avatar
Thumbs up
This is for a GE8.
Old 07-03-2013, 04:56 PM
ck42's Avatar
That picture certainly doesn't look like MY ge8.
Old 07-03-2013, 05:07 PM
FitStir's Avatar
Probably because YOUR GE8 doesn't have OEM (Honda) Navigation... like mine in the pic does.
Old 07-03-2013, 05:09 PM
ck42's Avatar
Interesting. Mystery solved.
Old 09-16-2014, 09:53 AM
fitfun2drive's Avatar
Where the plug is?
If you do not mind, can you point out the plug in your picture for me?
Thank you
Old 09-16-2014, 10:13 AM
It's hard to see in that picture, but it's a white plug attached to the back of the air direction knob, just behind the defrost position.
Old 09-16-2014, 10:14 AM
FitStir's Avatar
Thank you
Right above the power outlet sticking through the opening is the plug. There's a panel piece that covers that area, in my pic it's removed.
Old 09-18-2014, 11:29 AM
Thank you both of you for answering my question.
y950129
13
11-19-2010 09:06 PM
vinnymac
10-31-2010 10:22 PM
kamakurakid
02-19-2009 12:00 PM
DC_Native
09-22-2007 03:31 PM
mimpi
11-27-2006 10:15 PM
Quick Reply: DIY disable A/C auto on when defrost selected
