HELP! rear window washer fluid sprayer not working...
so the rear sprayer thing is not working... i can hear the pump motor trying to pull fluid through, but nothing comes out, i'm not out of fluid... the fronts are fine, any ideas whats wrong, or should I just bring it in (i'm under warrenty) thanks fir any help!
So instead of creating a new thread, i thought i'd just post in this thread.
My sprayers work...maybe too well...
My rear's leak. I havent used my rear sprayers in over a week and every day once i drive it or just park it, there is water coming from the sprayer.
Is there a fix for this?
Here's a photo. It gets dusty after driving up mt. hamilton.
Maybe pull open the pass side front inner fender liner, you can see the pump there. Pull the hose for the rear (not sure which it is) then activate the rear pump and see if it sprays there. I ran into an issue like this with my Durango when I had it, I bought a new pump and all but it turned out at some point someone must have dropped/put a tissue or something in the washer tank and it just plugged up from the inside. Just tossing an idea out there.
