Cracked touchscreen
Old 03-14-2016, 08:25 AM
Michelle Pendergrass's Avatar
Cracked touchscreen
I own a 2016 honda fit (3 months old) and I stupidly cracked the touchscreen on the dash while putting a piece of lumber in my car. I went to the honda dealer and they quoted me over $4000 to fix it. Does anyone have any knowledge on this? Is it worth it shopping around for a better deal?
Old 03-14-2016, 11:22 AM
You can search, but the HU is stupid expensive, tied to the VIN#, has to be special ordered, and only the dealer can do this work. Sorry to hear bout the screen.
Old 03-16-2016, 10:58 AM
Wow, I would talk to ur insurance agent for some help. Unless u want to dish it out urself.
Old 03-25-2016, 10:17 AM
bargainguy's Avatar
$4K is a lot for that head unit....that's 20-25% of the new vehicle cost. Whoa.
Unless you really love the stock head unit, I'd be considering an aftermarket replacement. Chances are you'll get better functionality than your stock unit, and come in way under your $4K replacement quote. Unless you get a really high-end replacement, should be able to stay under $1K including installation.
Old 03-25-2016, 05:56 PM
dwtaylorpdx's Avatar
Just googling around I see units that supposed are compatible with the fit, wonder if they expect you to keep the original??
Old 03-26-2016, 09:24 AM
If you go aftermarket, the garnish from metra is the only thing close to fitting the dash from what ice researched. If you go aftermarket with say a pioneer, then you will lose the backup and lanewatch camera. I beleive you will also lose the trip computer and clock function as well.
In theory to retain at least backup camera function, you would have to disconnect it from the gauge cluster control module which is accessed by the head unit through the canbus and directly connect the camera outputs to the head units. Some adapting may be required though. Lanewatch if your aftermarket head supports two camera function the same procedure would apply, but likley the aftermarket headunit (i only looked at pioneer) doesnt have a trigger function to activate lanewatch when the blinker is activated.
Ive done a lot of research on this, unfortunately the OEM HU has good hardware, but the software is intenionally bricked and UI is sluggish and slow. Least we can unlock it while driving to have full functionality.
Old 03-26-2016, 08:21 PM
2Rismo2's Avatar
So you're telling me that a random act of Street crime caused damage to your head unit right? Because your deductible is probably much cheaper...
Old 03-27-2016, 11:41 AM
frostedfrank's Avatar
that is crazy expensive for a unit that probably costs $200 to Honda.
If there are no other options I would check with the insurance as others have said
Old 05-13-2016, 07:35 PM
Bob Levine's Avatar
Junkyard may have teletype service to see if a unit can be located at another yard.
Might ask Honda cost of installing a salvaged unit.
Old 05-14-2016, 10:55 AM
Or do a 1 time fix gesture.
Old 10-20-2016, 01:54 PM
fitchet's Avatar
Wow...
Older post, but 4 grand to replace that head unit?
Well thanks for the warning.
Guess I'll be upping my "Be Careful" around the touch screen quotient.
Wonder how the OP approached the situation?
If I'm going to invest over 4 grand into a vehicle....just to keep it OEM factory?
It's a nice touch screen, with nice functionality...but I'd be hard pressed to make that investment.
Old 10-23-2016, 08:07 PM
per my post, i would seriously consider using insurance to fix it.. unless there are clean oem-looking trims available and install a nice doubledin HU with carplay.
Old 10-26-2016, 02:38 PM
fitchet's Avatar
Sure. I'd at least try.
But at that cost?
If Insurance doesn't cover it, it almost forces you to look at an aftermarket choice.
Kocho333
10-10-2017 09:56 PM
vaguba
09-09-2014 12:56 AM
Cordizzle4life
03-21-2014 05:45 PM
taFITta_sport
09-14-2008 08:41 AM
bank head
05-15-2008 09:51 PM
Quick Reply: Cracked touchscreen
