Fitting in springs...
Old May 11, 2007 | 08:50 PM
kentris's Avatar
Hi
I got my springs ready to be fitted. I've had a look at the guide on hondafittuner.com found here -> Tutorial on installing lowering springs
Now I understand perfectly well on the rear suspension and I had a look this morning and it doesn't seem that hard. Actually looks quite piss easy.
However the front suspension, going from the pictures, half the time I don't understand what is happening.
So can anyone explain like sorta briefly/detailed what is happening in the pictures for the front suspension?
It would help!
Old May 12, 2007 | 09:39 AM
WhatFreshHell's Avatar
Wow...
ALL the work I put into this thread got deleted...
They deleted the WRONG THREAD>..
sigh
Old May 12, 2007 | 01:19 PM
kentris's Avatar
What the. Damn this bloody sucks.
Well freshhell, I remembered most of the stuff you told me.
The install didn't go so well though, I hit a bit of a snag. There's one bolt that seems to be connected to something (it's like this long bar that goes down and then underneath the engine)
Yeah, I couldn't remove the bolt not with all my strength in the world lol. I think I need a air powered gun to remove it.
Old May 17, 2007 | 10:08 PM
adamhassett's Avatar
The bar you are looking at is the drive shaft, when taking out your front suspension be very carefull not to let this pull out of the drivetrain too far or it is a real pain in the butt to get back in. If you follow the pictures on hondafittuner.com just take out the two big bolts connecting the suspension to the rest of the wheel assembly and then the small nut connected to that small bar that goes up further on the suspension. Again I caution you to make sure you dont let that drive shaft slide too far out or it can be a real pain to get it back in without taking the rubber boot off. Which is even harder to put back on! Any questions let me know, I just did this yesterday and am pretty sure I had every possible problem!!!
Old May 18, 2007 | 12:35 AM
TomiGunz's Avatar
Wrong bar..
The bar he's talking about is the sway bar. I posted on another thread, After you remove the tire, use a 2nd jack to jack up the suspension. Once you line it up right, you'll be able to pop the swaybar linkage off of the strut. You'll have to do the same when you install it back onto the strut. I think it's a 14mm hex. I unbolted EVERYTHING by hand...
If you have any questions, PM me.. I'll help you out. I can give you my phone number too if you want me to talk you through it..
Old May 28, 2007 | 10:46 PM
kentris's Avatar
lol thanks for the info but I've booked it in to a garage my uncle knows to get 'em done.
And about the phone call, haha, don't think my mother would approve of an expensive international phone call :P
Old May 29, 2007 | 12:00 AM
TomiGunz's Avatar
oops, just realized you're from the UK!
Good luck on the drop
peopleintheskyy
Aug 23, 2018 02:58 PM
coupdetat
Jul 1, 2013 10:21 AM
GoFits
Apr 29, 2012 09:52 PM
gmane
Apr 19, 2008 07:01 PM
LowTekk
Nov 1, 2007 07:18 AM
