Programming OEM Fit Sport Key?
Old Sep 3, 2008 | 06:39 PM
Devolutionized's Avatar
So I only got 1 key when i bought my Fit (got it used), and i really need a back-up. I have a fit sport with keyless entry, and my keyless entry buttons are on my ignition key. A friend at a dealership can get me the oem key for like $35, but then said it would be like another $90 in labor to program it.
When i searched, i found Mugen_Dom's post on the acura TL switchblade conversion. Would the following sequence also work to program an OEM Fit key? And what about the Immobilizer Chip?
Mugen_Dom's Programming Sequence:
To program the remote, you first have to disable the memory feature!
All you have to do is hold the lock and unlock buttons together, until the LED on the remote blinks twice. This will mean that it's disabled.
PROGRAMMING THE REMOTE TRANSMITTER (KEYFOB):
NOTE: It is important to maintain the time limits between the steps. Make sure the doors, the hood and the hatch are closed.
1. Turn the ignition switch ON (II)
2. Within 1 to 4 seconds, press the transmitter lock button.
3. Within 1 to 4 seconds, turn the ignition switch OFF.
4. Within 1 to 4 seconds, turn the ignition switch ON (II).
5. Within 1 to 4 seconds, press the transmitter lock button.
6. Within 1 to 4 seconds, turn the ignition switch OFF.
7. Within 1 to 4 seconds, turn the ignition switch ON (II).
8. Within 1 to 4 seconds, press the transmitter lock button.
9. Within 1 to 4 seconds, turn the ignition switch OFF.
10. Within 1 to 4 seconds, turn the ignition switch ON (II).
11. Within 1 to 4 seconds, press the transmitter lock button.
12. Confirm you can hear the sound of the door lock actuators within 1 to 4 seconds, then push the transmitter lock button again, or the code will not be stored.
13. Within 10 seconds, press the transmitter lock button on any other fob you wish to program. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and remove the key.
15. Confirm proper operation with the transmitters.
Old Sep 3, 2008 | 09:59 PM
Fa1's Avatar
Fa1
That only programs the lock/unlock/panic buttons to your car. You will still need to get the immobilizer chip programmed at the dealer.
Old Sep 4, 2008 | 01:18 AM
i thought that would be the case. unless the fit immobilizer chips were universal (which eliminates the point of the immobilizer in the first place). so either way i have to pay the dealer to program the key, right?
Old Sep 4, 2008 | 01:41 AM
Fa1's Avatar
Fa1
Yes, should be a quick 10min job with their hds tool.
Old Mar 20, 2009 | 08:51 AM
amason4's Avatar
Hi everyone. I also just got my base model 2009 Fit and only wanted the keyless entry so did not opt for the extra 1500 dollars for the sport. This forum has been very helpful. I just ordered a keyless remote off of EBay and I am planning to just use the remote to lock/unlock and the key that came with my car in the ignition. The remote includes a blank key which I will probably just leave blank for the time being although I also like Firefox's idea of cutting it off and attaching the original key to the remote. Anyway the key and remote was $39.92 with $7.49 for shipping. If it works it will sure beat paying extra for the sport or giving the dealership more of my money to "install" keyless.
Old Mar 20, 2009 | 10:33 AM
awptickes's Avatar
https://www.fitfreak.net/forums/2nd-...ase-model.html
Old Oct 31, 2023 | 01:34 PM
PatagonianDuck's Avatar
Worked perfectly thank you. 2007 Fit Sport. I will add that I never saw the two red led blinks when trying to "disable memory feature". Key has never worked before to my knowledge, so it may have already been disabled.
Old Oct 30, 2024 | 11:55 PM
nrivoli's Avatar
sorry to wake up this post that many years later
Question, does the blade itself has any chips inside? I got a spare used key from Japan, also got some blank keys from aliexpress, my plan was to program the smart key, and then cut the key
but if the actual blade needs a chip then cutting the key is no use other than opening the vehicle?
My key is 72147-SFA-J01, you need to remove the key from the casing (turn to start), car is a 2009 Ge6
Old May 30, 2025 | 09:31 PM
iismileyll's Avatar
I got a blank from aliexpress. Had Ace Hardware cut the key for 5 bucks. My old key got broken. But the immobilizer chip is a little glass pellet in the original key. I taped/glued it near the front of the new key so it wouldn't rattle around. I still have the old blade, but it'll unlock the car, but won't start. I've thought about just hot gluing the chip inside the steering wheel column so any one with a key could start it. I'm not too worried about it now, it's a 2007 beat the duck up city car.
FitG8Mugen
Apr 28, 2019 10:55 PM
jinuevo
Sep 12, 2018 06:14 PM
DeathKitten
Mar 27, 2011 08:08 PM
vile10
Nov 20, 2008 12:44 PM
stacey14
Jun 22, 2006 12:26 AM
