No crank no start
Old Sep 11, 2019 | 12:47 PM
Saxy's Avatar
No crank no start
Hey there, a couple months ago my 07’ started doing a progressively slower crank until doing nothing and would not start. Since then I’ve replaced the battery, starter, and ignition switch. The sucker still won’t start. My starter is t cranking at all and for the life of me I can’t figure out why it isn’t getting power. Any of you have ideas for what to try next? I’m getting desperate haha
Old Sep 11, 2019 | 01:16 PM
Alexander Chernoch's Avatar
I would start with checking all of your grounds and ground straps. I had a similar issue with a 97 Jeep and that was my cause. Hopefully this helps.
Old Sep 11, 2019 | 01:44 PM
doctor J's Avatar
Automatic or manual?
If automatic , a neutral safety switch on the side of transmission may be a suspect
Old Sep 11, 2019 | 02:27 PM
Saxy's Avatar
It’s automatic, but I don’t get any response from the starter in neutral still so I don’t think that’s the suspect
Saxy's Avatar
I’ll give that a shot! Thank you
Old Sep 11, 2019 | 03:52 PM
doctor J's Avatar
Are you majoring in philosophy ?
All you need to do to rule the NSW out is to bypass a starter relay with a suitable jumper
If starter works consistently after this, try different relay and/or troubleshoot the neutral starting switch circuit (easier to say than done).
Rrff1954
Aug 9, 2018 06:52 AM
Philip May
Aug 8, 2017 02:29 AM
manbat39
Aug 4, 2005 05:30 AM
kevininiowa@aol.com
May 18, 2005 02:25 AM
mmdir2002@yahoo.co.uk
May 4, 2005 11:16 AM
