Honda fit 2004 issues
Old Nov 26, 2019 | 08:33 AM
Keff Kelvin's Avatar
So i have a honda fit jazz 2004 model that has been really bothering me. I recently changed gear due to jerking and now the new gear shows a blinking D light and the rpm goes really high at low speed. When i noted no improvement i changed its ecu. It performed well for a few kilometers and i am back to the same problem. Blinking D light and very high rpm causing it to rev. Also before i used to do 20+ kilometers per litre now i am at 10km/ltr. I did a diagnosis today and got these codes 70-03(p0700) a/t And 53-01(p1887) vabs vehicle speed signal input inconsistency. Kindly help because i have really spent alot on it. Thanks
Old Nov 26, 2019 | 09:20 AM
tyrtill's Avatar
Most likely a bad Torque Converter Switch in the transmission. However it could also be wiring. https://www.transmissionrepaircostguide.com/p1887/
Your transmission is going into limp mode which normally means 2nd gear because of this issue and that's why you're getting the high rpms.
Old Nov 27, 2019 | 04:16 PM
the blinking D light has been sorted out, now the only problem i have is high rpms, high revs.
Old Jan 3, 2023 | 08:21 PM
Josmer12's Avatar
How did you solve the transmission jerking? my d light doesnt blink but it tends to jerk a bit and sometimes it lags going into gear, the only code it shows on my basic scanner is the p1887 the torque converter release switch
Muhammad Abubakar
Jun 2, 2018 02:03 AM
doctor J
Aug 23, 2016 02:53 PM
Romulus
Sep 18, 2010 09:58 AM
wilcoholic
Apr 25, 2010 11:29 PM
pastafarian
Jan 23, 2008 01:09 PM
