Fit code p0443
Old Nov 28, 2019 | 05:50 PM
Safehandle's Avatar
Fit code p0443
Hey guys, I’ve been messing around with making a custom intake for my fit, and I finally got something I like. The only problem is I’m getting code p0443. I’m assuming it has something to do with the changes I’ve made, I’m just confused as to why? The code says EVAP canister purge valve circuit malfunction. Nothing is really different from how the intake works from oem, except maybe more air flow? Any thoughts?
Old Nov 30, 2019 | 10:55 AM
eulogy's Avatar
i assuming you just put intake in? did u disconnect your negative battery terminal for a few minutes to reset ECU?
Old Nov 30, 2019 | 01:11 PM
Safehandle's Avatar
yeah I had it disconnected for about 20 minutes and the light came on after about a minute of driving
Old Nov 30, 2019 | 01:42 PM
NEGD3's Avatar
That purge valve from the code is right on the throttle body - did you double/triple check the vacuum and electrical connections?
heres a troubleshooting guide for that 0443 code that might help - it’s for EU/UK cars..so idk how accurate it will be, it looks pretty close.
DTC Troubleshooting: P0443 (92-4) (5MT)
or if you have the stock air box - put it back, and then see if the code still shows. Then you’ll know if it’s the the fault of your in or in the purge valve/sensor
Old Nov 30, 2019 | 03:56 PM
Safehandle's Avatar
Ok I feel like an idiot. I checked the connector you mentioned and I didn’t plug it in all the way.. Nonetheless I plugged it in and the code is gone!
Safehandle's Avatar
Would anyone be interested in a build thread for this intake? It could be all in my head but the car does feel like it has more power in the higher rpms. Hopefully I can get it on a dyno to see.
FITDragon
Nov 11, 2021 09:08 PM
drkatherine1
Mar 27, 2017 09:52 PM
madvibes
Aug 31, 2010 07:16 PM
harlen
Mar 6, 2009 05:37 AM
FELIXY69
Jan 8, 2009 06:06 PM
