Power Steering stop working
Old Jun 10, 2020 | 03:04 PM
manterola's Avatar
Hi All,
This is my first post in the forum but I've been reading you for years.
I drive an enjoy a 2008 Fit first generation which I (used to) use to commute: about 10 miles each way during weekdays and very light use during weekends. Right now it has about 85,000 miles
I've been working from home in the last months so my Fit has been sitting there for weeks, I used it like once every two weeks. Last time I tried to drive it the electric power steering stopped working.
I read that's common, but after a "reboot" (like a computer) usually it should start working again.
In my case it looks like it just died, once and for all. It never worked again. I used one of those cheap Bluetooth ODB-2 interface to check for some error code, and the ECU says "no codes", everything look right from the ODB2. I just have the steering wheel symbol on in the dash, "check engine" light is off.
So I was wondering if there is a fuse, I can check. Otherwise, it looks like I might need to go the Honda dealer to see how much $$$ for replace the EPS
I also read here in the forum about recall of the EPS, but I guess my car is too old... I am wrong?
Is there any other thing I can try?
Thanks in advance for your help...
Regards!
Old Jun 12, 2020 | 05:20 PM
doctor J's Avatar
Honda extended warranty for 10 years.Since your problem is looking differently compared to TSB, I would check the steering gearbox motor wiring first.
Old Aug 7, 2020 | 10:11 AM
jy_'s Avatar
jy_
Where and what exactly should I check for in the gearbox motor? I have a similar issue
Old Aug 10, 2020 | 02:24 PM
doctor J's Avatar
Under brake booster you will see 3 thick wires
Felix el gato
Feb 20, 2025 10:48 PM
1toughfit
Nov 23, 2015 07:30 PM
jdzz
Feb 28, 2011 12:34 PM
willy65000
Feb 18, 2009 11:07 PM
fit2bowner
Oct 8, 2008 05:50 AM
