Mass air flow sensor 2008 fit sport
Old Jul 10, 2020 | 03:23 PM
Thomas Hurst's Avatar
Can anyone tell me if 2008 Honda Fit Sport has a mass air flow sensor & if so were is it located picture would be great I know it has a Intake Manifold Temperature Sensor that i am replacing thanks
Old Jul 11, 2020 | 11:48 AM
idrivemyself's Avatar
The first gen Fit does not use a MAF.
Old Jul 11, 2020 | 12:28 PM
macbuddy's Avatar
The ‘07 and ‘08 Fits use a MAP sensor. It is located right behind the throttle body.
Old Jul 11, 2020 | 12:33 PM
can the map have the same kind of problem and need to be taken out and cleaned with maf cleaner??
Old Jul 11, 2020 | 12:48 PM
Old Jul 11, 2020 | 05:34 PM
macbuddy's Avatar
I recently had a P0172 light up. After I cleaned my MAP sensor, the CEL has yet to come back. I am not certain if that was the fix, or if it was just coincidental.
To answer your question, “Google” said that the MAP sensor can be cleaned.
Old Jul 11, 2020 | 06:37 PM
i just got brand new OE for 15 bucks be here friday figured what the hay
Old Jul 12, 2020 | 12:52 PM
Fitguy07's Avatar
Yes, you can pull the map sensor and clean it with electronic parts cleaner. Let it dry and install with a new o ring. That's if it's actually dirty and not a voltage issue.
Old Jul 12, 2020 | 01:02 PM
running lean said they think dirty or bad so jusy bought new for cheap we will see what happens
Old Dec 6, 2022 | 04:40 PM
FutureDwight's Avatar
Did it work?
Jerry Mt
Jul 11, 2020 05:45 PM
Joshwarwickb17@yahoo.com
May 4, 2020 09:44 AM
Destiny
Dec 8, 2017 04:20 PM
JBolt
Jul 8, 2017 06:30 PM
illmitch
Apr 6, 2011 03:34 PM
