Squeak and battery light when going over puddle
Old Dec 31, 2020 | 02:50 PM
Cwong's Avatar
Hello
I am experiencing issues with loss of power, battery light coming on and if ac/heat is on the blowers force drops significantly when going over puddles. I am assuming this is from a worn serpentine belt. However I know my battery is weak as it does once and has been living off of a jump...cold weather starts turns over with no issues however it makes a cranking sound. Kinda like the ignition is already on and I turn the key extra. Let me know your thoughts. I have duralast belts coming in tomorrow
Old Dec 31, 2020 | 02:56 PM
Jared592's Avatar
Definitely sounds like a belt issue to me: when the belt slips the alternator isn't getting spun fast enough to keep the voltage above the minimum threshold, which triggers the battery light. If you know your battery is bad, definitely get that changed out too when you can. There's only one belt on a Fit btw.
Old Jan 1, 2021 | 02:08 PM
doctor J's Avatar
Probably missing engine shield too!
crunchie
Jan 31, 2019 03:31 PM
Bounce
13
Jul 6, 2018 05:30 PM
ihmcguinness
Oct 1, 2015 04:21 PM
zader
Jan 26, 2014 03:48 PM
blaaaackfit
Jun 4, 2013 04:41 PM
