Starter trouble/weird noise
Old Jan 6, 2021 | 07:20 PM
popsbassrosin's Avatar
Hi all! This is my first post here, though I've been a lurker on this forum for awhile. I have a 2007 Fit basic with around 175k miles that has been making a weird sound at startup recently, as you can see in this video below. Doesn't always happen, but when it does I have to take the key out and try again, which usually does the trick. I've seen a few threads about weird sounds coming right after/at the same time as the engine turns over, but my issue seems a little different, since the car doesn't actually start when it occurs. Recently had the battery replaced, and had the spark plugs and ignition coil done about a year ago. I do live in Chicago, so it's been cold, but this does happen sometimes even after a drive when the engine is still hot.
https://www.youtube.com/watch?v=BhHf...ature=youtu.be
Old Jan 11, 2021 | 02:48 PM
doctor J's Avatar
So it clicks once, then second time it starts normally? Check battery connections
Old Jan 11, 2021 | 05:57 PM
Thanks for the reply. Connections are all tight, my mechanic put a shim on the positive terminal because it was a little loose. It's not so much a clicking but that whirring sound on that first start, pretty quiet in the video, headphones may help.
Old Jan 15, 2021 | 10:39 PM
okey0's Avatar
That’s a lot of miles if it’s still the original starter. May be time to replace?
Old Jan 18, 2021 | 03:38 PM
Yes it is the original, so I think you might be right, I'll have to get that checked out. Thanks for getting back!
Old Jan 19, 2021 | 11:57 PM
Ryan Hendrickson's Avatar
I'm interested to know if the noise goes away after a starter replacement.
Thanks
jond63
May 10, 2024 10:45 PM
jtm893
Oct 6, 2022 05:39 AM
Kavan Neo
Oct 30, 2020 02:42 PM
Glasswelder
Oct 10, 2018 05:25 PM
sheryllynn
Oct 27, 2017 08:41 PM
