Idle goes UP and DOWN at D or Drive mode.
Old Feb 18, 2021 | 03:52 PM
lwrnclxfit's Avatar
Whenever I put my gear in “D, S or L” (Automatic Transmission), my idle will bounce up and down. But whenever I put it on reverse, neutral, or park, I dont experience the up and down idle. This also occurs whenever im idling or at a stop/stoplight and my gear is in D. It gets worst when my AC is on. Any suggestions or any knowledge about this problem? I would highly appreciate any bits of information. Thank you in advance!
Old Mar 27, 2024 | 06:53 AM
Keith Mubaiwa's Avatar
Did you find the solution to this problem ,i am expierencing the same problem
Hello,did you manage to solve the problem with your car ,I have a honda fit 08 and i am expierencing the same rpm flactuations when in drive mode and r mode ,only at a stop.please help
Old Mar 27, 2024 | 07:53 PM
neurognome's Avatar
I had these symptoms and I did a valve adjustment as well as changing out spark plugs and coils. I didn't have any error codes, but one of those (or all 3??) fixed the issue.
Old Mar 30, 2024 | 12:56 AM
Ok will do the valve adjustment ,had already changed the plugs and the coil packs ,thanks will uodate
Old Mar 31, 2024 | 01:41 PM
FionatheFit's Avatar
I had this same issue in my last car (95 civic). I ended up having to replace the air idle control valve (it was beyond attempting to clean.) The first thing I would do is to check for vacuum leaks though
Dean
Mar 15, 2025 01:54 PM
Slasher
Jun 12, 2013 05:34 PM
redfit_pr
Jan 14, 2010 03:29 PM
BenW
Dec 26, 2008 06:09 PM
danger69
Aug 31, 2007 10:00 AM
