New Alternator, Good Battery, still charge system light?
Old Jul 18, 2021 | 08:50 PM
soycory's Avatar
Unhappy New Alternator, Good Battery, still charge system light?
On my 2008 My charge system light was intermittently coming on. I tested with my OBD2 scanner and when the light was on I was getting 12.X volts and when it was off 14.X volts. I needed to get in a do my starter that would grind in cold weather... I got everything back together and now I get a consistent 14.2-14.7 volts on my charge system, but now the light stays on the whole time... I checked the battery terminals, had the battery tested, and had the charging system tested at Advance. All say the system is good. Is there some sensor that could have gone bad somewhere or something that I shorted out? I did not see anyone with a similar issue when I searched so not really sure what to look for.
Thanks!
Old Aug 2, 2021 | 07:45 PM
soycory's Avatar
Thanks!
Turned out the replacement alternator must have had something wrong as I got a replacement for the reman one and the problem is gone.
Old Apr 14, 2023 | 05:51 PM
Chitown Fit's Avatar
Go To Your Local Honda Dealer.
Have your local Honda Dealer see what the problem is.
AstroPacillo
Sep 8, 2020 11:01 PM
lister
Mar 8, 2020 12:58 PM
crunchie
Jan 31, 2019 03:31 PM
scootley
Dec 6, 2015 09:46 PM
blaaaackfit
Jun 4, 2013 04:41 PM
