Rear silencer change
Old Sep 30, 2021 | 11:34 AM
Hopipola's Avatar
Hi all.
After I'd been critisized in jazzclub (uk version of fit freaks) i joined this forum officially 😌
Need a little help to get my head around.
So I'm thinking to cut off rear silencer and replace with smtn like
https://www.ebay.co.uk/itm/Hornet-Ex...-127635-2958-0
Because original exhaust is resonated would this affect performance in bad way!?
Would that give deeper lower tone!?
And would it be easy to swap without welding!?
P. S. Your Jazz'es, Fit's look so much better than europe versions 😭
Cheers
Old Nov 3, 2021 | 04:34 AM
Pki249's Avatar
Hey,
YOu can't install it easily I installed this (https://www.ebay.de/itm/Schalldaempf...-127634-2357-0) last week the sound is amazing with high RPM it feels so good, but the install was hard I needed to cut my muffler's pipe and connect to this I tried it without welding but there was a lot of air leaking so I had to weld it and needed to cut the rear pumper to make it fit, but it's was worth it really, I didn't see any performance change
Old Nov 3, 2021 | 10:03 AM
James Butler's Avatar
I changed to an aftermarket muffler 6 years ago and i like it. I had one like you showed on earlier cars but after a few years they rusted out and broke. Make sure they are stainless steel for long life. On my Fit muffler I bought one of the stainless sreel ones off Ebay and have had no problems. I paid to have the stock muffler cut off and the new one welded in place . Well worth the money and cheaper than buying a rear assembly made for the Fit. Good luck.
James
Old Nov 9, 2021 | 01:16 PM
Hopipola's Avatar
James
How much did it cost you for labour!?
Old Nov 9, 2021 | 09:35 PM
I bought the muffler for $50.00 USD with free shipping off of Ebay and the muffler shop charged me $60.00 USD to cut off stock muffler and weld on new one and two brackets to position it properly. My stock muffler still in garage in case I need to put it back on.
Hope it helps
James
MaXpeedingRods
Mar 25, 2021 09:38 PM
Jasonvicktory86
Oct 4, 2019 11:49 AM
KKiernan
Aug 18, 2019 05:19 AM
User1
Jun 27, 2019 12:39 PM
vinylengraver
Sep 27, 2018 10:49 PM
