2008 fit surging when cold
Old Jan 26, 2022 | 09:06 PM
steveJ's Avatar
Hi, Im trying to get some feedback. I have an 08 fit with 120K miles. It just started surging (or anti-surging if that is a term) when it got cold a couple weeks ago (below freezing temps). It lasts for ~5-10 minutes (or about 4 miles) and then it purrs just fine. The surging/hesitation is cyclic of about 3 seconds and lessens in intensity but stay the same frequency as it gets closer to going back to normal running. I did the valves and cleaned the throttle body, and it did not fix it. Changed the air filter, nada. So my list of things it could be include:
-bleed coolant
-PCV valve
-MAP
-'new' throttle body
-engine coolant temp sensor
-EGR valve
-Fuel pump
-fuel filter
Any help would be GREATLY appreciated!!
Old Jan 27, 2022 | 01:27 PM
doctor J's Avatar
valve clearance adjustment...
Old Jan 27, 2022 | 06:50 PM
steveJ's Avatar
I had already done that (that is what I meant when I wrote that 'I did the valves')... didn't fix it...not the problem...so now Im on to the next on the list.
Any suggestions? My best bet is the EGR valve needs a good cleaning now. Anything else higher on the list than this?
Old Jan 29, 2022 | 05:24 PM
MUDKIP's Avatar
From what I've seen and read, the passages do get dirty along with the EGR itself.
I would take off the EGR using some cleaner on it and the bottom passages to see if it helps.
Old Jan 30, 2022 | 02:51 PM
steveJ's Avatar
Update: problem found!
-bleed coolant
-PCV valve
-MAP
-EGR valve
-Fuel pump
-fuel filter
So I read online about someone else that had similar symptoms with a honda civic....and it was with the O2 sensor that I replaced already; so to see if the surging was a result, just unplug it and see if the surging continues...so I unplugged it and BAMO surging gone! Turns out that the $45 O2 Bosch that says that it is compatible is not so much. I just ordered a Denso that was 65% off for $120. Looks promising though.
Old Feb 1, 2022 | 10:16 AM
doctor J's Avatar
Crappy replacement parts is the second case of the car problems after design/assembly defects!
This why I am telling "OEM or .. junk yard parts only"!
Old Feb 4, 2022 | 02:47 PM
Stephane's Avatar
Posted this in a random thread somewhere on accident:
I had this issue and tried a bunch of things. I did valve adjustment at the same time as replacing the ignition coil pack and that seemed to do it.
I had previously replaced the spark plugs, cleaned 02 sensor, replace map sensor. The spark plug replacement seemed to alleviate the issue but only for a few days.
You might have just 1 or 2 bad coils which you can swap around and try new ones to identify them but I just replaced all 4 to be safe.
Lastly I had this issue for the better part of a year before the car ever threw and engine code. Forget the code but it was a misfire code and told me the cylinder.
Ymmv but maybe something to check if you have exhausted other options.
JWoneswitz
Feb 4, 2022 02:42 PM
JerryHughes
May 4, 2019 09:20 PM
geepondy
Jun 23, 2016 12:26 PM
Bigger On The Inside
Jan 25, 2015 11:20 AM
bensenvill
26
Dec 23, 2014 04:39 PM
