Tires on '07 hard to find
Old Oct 6, 2022 | 12:22 AM
Hootie's Avatar
Tire selection for 195/55R15s has been slim pickings for quite some time (Tire Rack showing a total of 20 options)... 205/50R15s were a very common alternative size though is a smaller OD tire but are also slowly dwindling down option wise as well . TR is showing 21 options currently BUT they're also mostly summer or track tires with only 3 all season options.
The only plausible option I can think of its looking into 185/60R15s which shows to have 37 tires to choose from according to TR as well as mostly all seasons with a few snow/winter tires in the mix. You'll be going down 10mm in tire width, a pinch taller than the OE Sport tire which has an outer diameter of around 23.4 inches if memory serves me right (185/60R15 is around 23.74 inch in OD).
This should be ok if you stay on the stock Sport (assuming you have them) wheels and at stock ride height, if you later switch to an aftermarket 6 inch wide wheel with an offset in the mid/high 30mm to very low 40mm then you may be susceptible to experiencing tire rub on harsh bumps or dips.
Originally Posted by KrautBurner
as long as you have same sized ones on both sides of the front, you'd be ok
OE: 175/65R15
+0’’These tire sizes fit the original wheel of your vehicle and generally don’t require new wheels.
205/55 R1515”Wheels
175/60 R15 195/55 R15 185/65 R15 195/60 R15 185/60 R15
"undersized tires" These smaller tire sizes match your original wheel diameter but may require new wheels due to the narrower tire width, and may impact speedometer accuracy/vehicle handling
205/50 R15 185/55 R15 195/50 R15 165/60 R15
"oversized tires" These larger tire sizes match your original wheel diameter but may require new wheels or fender modifications to prevent rubbing due to the tire height, and may impact speedometer accuracy/vehicle handling.
205/60 R15 195/65 R15​​
Great and accurate info for the GK5 and GE8... BUT not for the GD3.
They run the shorter 195/55R15 as its 15 inch option on Sport wheels.
Old Oct 6, 2022 | 12:23 PM
GrE8_Fit's Avatar
185 sounds perfect for a GD.
Old Oct 6, 2022 | 03:04 PM
Matt526l's Avatar
Originally Posted by domoMKIV
Make sure that if you order from Amazon, they are sold by Amazon. Then you at least have a 30 day return window (not sure when they start with the holiday return window that extends until January). I just ordered a pair of Yokohama tires for my '15 from Amazon, had no issues. Like someone else said though, you might be able to find a used tire shop and be able to spend less if money is an issue.
This. I return stuff back to Amazon all the time, and yes the tires I bought and linked to are sold by Amazon.
This also isn't my first time buying tires from Amazon. All reputable brands, second time buying these same exact tires but a different size (first time was 225/40/18 for my Lexus).
Old Oct 17, 2022 | 03:06 PM
Odie707's Avatar
I got a nail through tread and side wall commuting to work through a traffic zone (101 in Novato) I went to see what Costco had and saw they don't carry the size anymore online. I was wondering if we were located in the same area, to find out we are in the same town. lol
I work near an AAA auto center and they have Falken tires. Hate to mix and match but they are quick and easy to deal with.
Old Oct 19, 2022 | 12:19 PM
roja's Avatar
I have a Sport so it has the wider tires (195/55R-15) and the two best options appear to be Kumho Ecsta (there is an all season and a summer version) or the Hankook Ventus V2.
Redeye72
Apr 16, 2012 01:37 PM
tenura
Apr 12, 2011 02:11 PM
Justyna
Mar 1, 2011 09:16 PM
1990hondahf
Jul 12, 2009 10:11 PM
