What to do about terrible gas mileage
Old Feb 15, 2023 | 05:45 PM
Robear81's Avatar
Hey everyone, I've had my Fit since March. The first road trip I took on it had great gas mileage. I averaged about 40 mpg. A few weeks later it started acting up, it started to misfire and throw codes. I thought I figured out the issue. Which I replaced the coils and spark plugs. Which the check engine light went away. Still getting terrible gas mileage (23 mpg). I decided to check if there was any codes last week, there was the same codes that popped up before the misfire on 3 cylinders. So I checked to see if it was the coils again. They seemed to be good to go. I put in fuel treatment thing it could be a fuel issue. I unplugged the battery to reset the computer and all the codes disappeared. I drove it til the tank was low. I got slightly better gas mileage but still getting around 24-25. Only thing I could think of is possible fuel clogged line, fuel injectors or possibly bad fuel pump. Is there anything else that I could be missing or anything else I should look at?
Old Feb 20, 2023 | 09:29 AM
doctor J's Avatar
Did you use OEM parts (coils, plugs) from reputable source?
Honda is new BMW now, any non-genuine part (including air filter element and coolant) causes issues!
Old Feb 20, 2023 | 11:34 AM
Robear81's Avatar
The coils are Hitachi and I used NGK plugs. I test the coils and plugs. They work just fine. It's definitely a fuel issue.
Old Feb 20, 2023 | 07:55 PM
doctor J's Avatar
My next take will be valve clearance inspection / adjustment
as well as Gas pump unit electrical plug (it tends to burn contacts)
Old Feb 20, 2023 | 08:18 PM
GAFIT's Avatar
Just to reiterate the above...valve adjustment.
Old Feb 22, 2023 | 08:26 AM
Baldwin Nguyen's Avatar
I'm in the same boat as you (averaging around 22 MPG) but I recently did a valve adjustment and generally that noticeably improves your MPG so I would look into getting that done it you're long overdue. Some easier things to tackle are tire pressure & oil change.
ftlmatt
Jan 17, 2022 02:12 PM
Akorenhere
Nov 14, 2019 01:12 AM
TheWeirdFit
Nov 6, 2014 12:27 AM
AndrewLOL
Mar 31, 2011 11:36 PM
eddie777
Mar 4, 2009 01:46 PM
