CVT Mode switching issue
Old Aug 7, 2023 | 01:36 PM
Tarmac's Avatar
Hi everyone
A year ago i start gradually losing the CVT steering wheel buttons (also audio RCD buttons).
Both paddles, plus the 7speed button, was getting more and more difficult to select.
I had the feeling the a bad contact (due to dirt-dust) was happening.
I did ignore the issue since my wife doesn't really use the paddles.
But since last month, during driving the CVT changes mode, randomly!
From full D - CVT auto goes to CVT gear select, back and forth!!!
And this is happening more and more often.
At first i thought a sticky "7speed" button could be the case but it seems to me now, it's an CVT ECU issue or a steering swift switch?
Has anyone experience something like that?
If yes i would appriciate his input.
Best Regards to all, Dimitris
Old Dec 7, 2025 | 01:50 AM
Honda fit2008's Avatar
jazz 2008
This is exactly what happened to me recently! I haven't found a solution yet, but I suspect the problem is in the "clock coil" because I took the steering wheel apart and played with the coil a few turns in all directions and it stopped (the button still hasn't responded).
Old Dec 7, 2025 | 06:20 AM
Tarmac's Avatar
You are correct! Change it before it get any worse
Old Dec 7, 2025 | 08:23 AM
Did you replace the "clock coil" and solve the problem? Did the button work again?
ansys
Dec 27, 2021 05:08 PM
Hopipola
Nov 9, 2021 09:35 PM
Jasonvicktory86
Oct 4, 2019 11:49 AM
User1
Jun 27, 2019 12:39 PM
vinylengraver
Sep 27, 2018 10:49 PM
