rpf1 fitment question
Old Dec 8, 2023 | 02:23 PM
mifesto's Avatar
2007 fit stock, not lowered. rpf1 15x7 35mm offset on 195/50/15, would it rub? anyone have any experience w rpf of that spec?
Old Dec 14, 2023 | 02:30 PM
daiheadjai's Avatar
My GD3 on stock suspension did rub a bit at the back over big heaves/bumps only (it was fine pretty much 99% of the time) but over time, it stopped doing that (even over the exact same areas that used to cause rubbing).
I was also on 205/50R15 tires, so that makes my setup a little bit different than yours, but I'm very happy with the wheel/tire combo I went with (even when it rubbed, it only did so under rare occasions).
Old Dec 14, 2023 | 11:23 PM
mifesto's Avatar
wow that looks amazing, thank you for feedback
Old Dec 15, 2023 | 08:29 AM
daiheadjai's Avatar
You're welcome! I don't think you'll regret it - the car definitely feels more responsive on gas and brake.
Old Dec 19, 2023 | 07:30 PM
silberfit's Avatar
looks great, are they 15x6, 15x6.5,15x7?
Old Dec 19, 2023 | 08:10 PM
daiheadjai's Avatar
Thanks! They were 15x7s.
Worth pointing out: by a sizing quirk, the 15x7s look way better than the 16x7s I put on my wife's Mazda3, as the spokes on the 15x7s aren't as convex as the 16s. The 15s have almost a deep-dish look.
The wheel/tire combo I have ends up almost flush with the fenders (maybe slight poke).
Old Dec 19, 2023 | 10:50 PM
silberfit's Avatar
what ET are they?
yeh 205/50r15 I imagine is the perfect size for this car.
Old Dec 19, 2023 | 10:59 PM
daiheadjai's Avatar
what ET are they?
Oops, forgot to mention that... +35 offset
Old Jan 20, 2024 | 12:39 AM
KTurd's Avatar
Not sure if this will help you but my setup is a bit different.
15x7 +35
205/50r15
lowering Springs
rolled rear fenders.
rubbed on bigger bumps in the rear and scrubbed the front on corners.
Old Jan 20, 2024 | 11:30 AM
daiheadjai's Avatar
Ooh, that looks good.
mifesto
Dec 9, 2023 08:34 PM
raquino925
Mar 9, 2018 03:03 AM
lakia5524
Feb 8, 2013 09:51 PM
SBT
Jan 18, 2012 03:43 AM
fitinfit
Mar 29, 2011 10:02 PM
