Looking for tips and lessons learned also…
Old Apr 27, 2024 | 08:54 AM
FionatheFit's Avatar
Hey yall, I recently adjusted the valves and somehow mucked it up and now the valves are making MORE noise then they were prior to my attempt. So that being said I'm going to go back in there and fix my mistakes. While I was in adjusting them the first time I noticed a tiny bit of play in each of the valves. What is the protocol for this? Do I pick it up and then put the feeler gauge in? Or leave it and slide the gauge in?
Does anyone have any tips or suggestions for how to make this job as accurate as possible?
Also, it has been about 1500 miles. Do you think I should replace the gaskets again?
And any torque wrench recommendations would be great. I had a Pittsburg wrench but am afraid it has gone out of spec. Not looking to break the bank but would be interested in buying a more reliable wrench.
Old May 10, 2024 | 01:58 PM
roja's Avatar
This is beyond my limited mechanical ability but I feel like this might be a reliable source to use (from Haynes):
Old May 10, 2024 | 02:24 PM
I really like these Haynes videos - at least the ones I’ve seen. Way better than just referring to the physical copy imo
Old May 13, 2024 | 07:13 PM
dwtaylorpdx's Avatar
Try Reading the instructions on how to adjust an old air cooled VW bug motors valves, the basic function is the same but for whatever reason it helps explain the technique better on how to use the feeler gauge and how to adjust them to spec.
FionatheFit
Jul 22, 2024 06:35 PM
MagicalSeats
Aug 7, 2022 01:04 AM
ihdu
Jan 12, 2009 12:24 AM
sy11580
14
Jul 24, 2008 03:45 PM
