Error code 970 help
Old Mar 8, 2025 | 09:09 AM
musky123's Avatar
Question Error code 970 help
i got this error code now 970 Pressure control C control circuit low code but i cant find any videos on how to fix that code , there a lot on utube showing other codes, but not PO 970 code any help would be nice, thanks. It,s a 2008 honda fit.
Old Mar 8, 2025 | 11:43 AM
GrE8_Fit's Avatar
Pzero97zero Looks like a transmission solenoid problem.
https://www.google.com/search?q=hond...=firefox-b-1-m
Old Mar 9, 2025 | 09:56 AM
musky123's Avatar
Does anyone have a picture of this pressure control solenoid c control circuit low because i keep seeing 2 different ones that say the same thing?
Old Mar 9, 2025 | 01:06 PM
jljimenezp's Avatar
A/T Clutch pressure Control Solenoid Valves
Hope this helps
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Mar 9, 2025 | 04:17 PM
musky123's Avatar
That,s assume thanks looks not to hard to change. Could you guide me to the correct one to buy for my 2008 honda fit im in canada.
Old Mar 9, 2025 | 05:41 PM
jljimenezp's Avatar
For the NA market the item is #006 on the parts diagram (link below): SOLENOID ASSY.B Part# 28260-RPC-004
https://www.bernardiparts.com/Honda/...assembly=13640
Check a local Canadian dealership website to confirm the part number. It should be the same (?).
Go through the diagnostics to make sure it needs replacing *before* purchasing any replacement.
Then calmly search online as dealer prices (if the part is available) are beyond eye-wateringly astronomical Found a couple on eBay.
Old Mar 10, 2025 | 07:53 AM
musky123's Avatar
thanks for all your help, i think removing the part and testing it with a 12 volt meter would be best, before changing the solenoid..
if i go to the scrap yard to get a oem part do you know what year cars will fit my 2008 honda fit.
Old Mar 13, 2025 | 11:23 AM
musky123's Avatar
when i install this new gasket does it require gasket sealer of any kind.
Old Mar 13, 2025 | 07:47 PM
jljimenezp's Avatar
No sealer. See page 14-221. Just be sure to torque the 6 bolts to spec 12 Nm, 8.7 Lb-ft (criss-cross & incrementally). Clean mounting surface etc. as outlined in steps 5-9.
Old Mar 14, 2025 | 04:23 PM
musky123's Avatar
so i took it apart and rats chewed the wires on that solenoid so im looking for a Harness Repair Kit, on amazon i guess ,not sure how to word it to make sure i get the correct one.
Old Mar 14, 2025 | 04:50 PM
jljimenezp's Avatar
For the NA market the damaged item is #008 on the parts diagram: WIRE HARNESS, SOLENOID Part# 28360-RMM-003. Available on ebay for approx. $72.
If you're handy with a soldering iron you can also find the individual 2-write plugs on ebay.
Search for "Automatic Transmission Control Solenoid Connector Standard S2931". Compare pin layout to yours etc.
Or search for "Honda ACURA Transmission Dual Linear Solenoid Connector WIRE REPAIR KIT 350-0146".
In either case be sure to use the option to "Check fitment" as a sanity check.
Old Mar 14, 2025 | 05:21 PM
musky123's Avatar
im trying to access the wire from the plastic cover case that all the wires run through but i cant open it? is there a way to do this or should i just break it open, to get at the wire so i can get enough to solder back togeather.OK i broke it off for now does this look like the part i need
Transmission Solenoid & PURGE VALVE Connector Wire Harness Plug For Honda Civic
I think im going to twist wires togeather and heat shrink it.
Old Mar 17, 2025 | 07:57 AM
musky123's Avatar
the new part has a black and red wire, the old part is black and blue wire, so does black go to black still?
Old Mar 17, 2025 | 05:38 PM
jljimenezp's Avatar
Do one plug at a time and set them down side by side preserving their orientation (i.e. connector toward you, wires on the backside, flat side of the plug with the tab down). Label them if you have to. Chances are better than good that the black wire is in the same position for both plugs.
cheychey
Nov 8, 2024 06:59 PM
FITDragon
Nov 11, 2021 09:08 PM
drkatherine1
Mar 27, 2017 09:52 PM
