Rough Idle, Hesitation
Old May 4, 2025 | 03:42 PM
FitMark's Avatar
I have a 2008 Fit Sport, MT, 200K miles. When idling the rpm surges (650-820 RPM) and there is some hesitation when accelerating. Gas mileage has also dropped from 35 mpg to 31. I’ve cleaned the throttle body and replaced the MAP sensor, and did an Idle Learn procedure, all with no luck. I did a scan and got the following codes: P0108, P0223, P0123, P2A00, P1172, P0113. Can’t find any vacuum leaks. Any ideas? I’m leaning towards a replacement throttle body.
Old May 6, 2025 | 04:16 AM
hugojose's Avatar
Have you ever changed spark plugs and/or ignition coils???
Old Jun 11, 2025 | 07:51 PM
FitMark's Avatar
O2Sensor
Solved. I replaced the upstream O2 sensor and problem solved, runs like new. I was able to loosen up the sensor after running the engine for 10 mins and the exhaust was hot.
BrinleyP
May 6, 2021 03:11 PM
radioarno
Feb 4, 2017 06:48 PM
doctor J
Dec 24, 2015 01:56 PM
Andre Lee
Oct 22, 2012 04:00 PM
Stiff
May 4, 2005 11:16 AM
