OEM Oil Filter On GD's
Old Feb 13, 2009 | 12:42 AM
YA2_user_GD3's Avatar
Has anyone had problems with the Honda OEM filters or any oil changes done by the dealership? I just found out the current 15400-PLM-A02 filters typically installed on our cars are made by Fram. After hearing about the Fram horror stories I'm a bit skeptical.
All I wanted to know is if anyone has had any type of problems using this filter or if people are just blowing this OEM filter made by Fram out of proportion.
Old Feb 13, 2009 | 12:50 AM
itsmeb*tches's Avatar
They are made by Fram to Honda's specs. I have also heard the FRAM horror stories thus why I use the S2K honda filters.
Old Feb 13, 2009 | 01:36 AM
Fa1's Avatar
Fa1
IIRC Filtech no longer makes honda filters, just fram.
Old Feb 13, 2009 | 01:42 AM
I just want to know if they're known problems, I'm about to put on the A02 filter tomorrow and I'm just worried about it. I bought Mobil1 full syn with it too. As long as there are no problems from dealerships or self installation i'm just gonna install it.
Old Feb 13, 2009 | 01:55 AM
Super Mario's Avatar
No problems. Used them all the time on my Civic. Think about it, the dealership still uses these on all of their Honda's, so if anything goes wrong we'd be the first to know! I've converted to Purolator Pure One filters for my oil change.
Old Feb 13, 2009 | 02:20 AM
yea but the dealership also claimed and made me pay for the drain bolt which they were suppose to replace during my oil changes..they havent and it's almost stripped, thats how i know they didnt change it.
Old Feb 13, 2009 | 02:31 AM
Were they supposed to replace it because it was stripped? Normally the dealers just put back the existing drain bolt. They don't give you a new one every time they change your oil. I've had to buy a new drain bolt before and it's only a couple of bucks.
I just found out that College Hills sells the A01 Filters. I might just have to pick some up from them.
2007-2008 Honda Fit Parts - Maintenance Parts
Old Feb 13, 2009 | 02:38 AM
azncarbos's Avatar
I have whole case of OEM oil filter and they are made by Honeywell........
Old Feb 13, 2009 | 03:03 AM
doctordoom's Avatar
Supervillain
even if fram oil filters are subpar in quality, as long as you perform maintenance at the regular intervals you won't have any problems.
Old Feb 13, 2009 | 02:03 PM
cab0053's Avatar
what are the fram horror stories? explosions? leaking? failing off?
Old Feb 13, 2009 | 02:17 PM
Tofuman's Avatar
Hamp and Wix oil filters are top notch. But I use K&N mainly because of the nut on the end. It make is so much easier to remove.
Old Feb 13, 2009 | 06:56 PM
SHG_Mike's Avatar
Exactly, oil and the filter are really a non issue if you change them every 3k or 5k at least. All the additives and super blocking filters do is just extend the amount of time between intervals for lazy people. The cheap fram stuff may be garbage but the higher end stuff is fine. We used Fram racing spec filters on our koni challenge car.
Ive used the OEM honda filter for 5 years on every honda ive owned with no issues
Old Feb 13, 2009 | 10:46 PM
VBP08GD3's Avatar
naw it should be alright...
Old Feb 14, 2009 | 11:56 PM
seeremlive's Avatar
Continuing your thought
......Which makes Fram and this is why some people are afraid of them.
I have never seen any conclusive controlled testing that shows Fram is any better or worse than any other main line filter brand. I have seen the cut open filter pictures and the anecdotal claims, but nothing firm. I would like to see some tests if anyone know of any from an actual lab.
Old Feb 15, 2009 | 01:27 AM
from that bob oil site, apparently they've run oil analysis. I had to tear up the OEM filter to take it off and i got a peek inside, looks pretty basic like fram's... uh-oh.
Old Feb 15, 2009 | 02:22 AM
kylerwho's Avatar
spoon fed
all companies have horror stories behind them. i had a few (not one but a couple) of bad fram oil filters that spit weird cloth pieces into my oil on my old subaru. i contacted fram about it and they said it was a manufacting defect and replaced the part for me.
im sure honda holds fram up to a higher par of workmanship but all companies have their ups and downs with products.
Old Feb 15, 2009 | 10:50 AM
Darkstars's Avatar
I always go to Honda and get an OEM filter and drain plug gasket and Mobil 1 5w20 from my work
honda2112
Sep 22, 2010 11:17 AM
helphelp911
16
May 31, 2010 09:12 AM
Mclaren_Honda
Nov 19, 2009 06:46 PM
fluffy bunny
Jun 16, 2008 09:54 PM
kkim
May 22, 2006 01:28 AM
