AT in drive, shows "4" on dash???
Old Jan 11, 2010 | 05:06 PM
xorbe's Avatar
I have the 2007 AT Fit Sport ... the other day I pulled onto the freeway WOT, and then cruising along at 65 mpg immediately ... but the car didn't shift to 5th, and then it showed "4" on the dash as if I were in paddle shifter mode for a couple seconds, and then it shifted to 5th and everything was normal again ...
Has anyone had that? 38K miles, maybe I better take it in for an AT fluid change.
Old Jan 11, 2010 | 07:05 PM
keepitpg's Avatar
i love college
you must have touched the downshift paddle. you can paddle shift while still in drive. i do it all the time.
Old Jan 11, 2010 | 07:07 PM
spreadhead's Avatar
^^^^ That's what it sounds like to me. Changing transmission fluid on a regular basis is a good thing to do, not changing it wouldn't cause what you experienced. FYI at approximately 60K miles your maintenance minder will code for you to change your transmission fluid.
Old Jan 11, 2010 | 07:11 PM
Perrenoud Fit's Avatar
Sounds like it 2 me 2 keepitpg.
Old Jan 12, 2010 | 02:14 AM
xorbe's Avatar
About a week before it did the same thing hanging onto 4th gear for a looong time but it didn't show "4" on the dash. Both times my foot was really into it. I really doubt that I've started accidentally pulling on the paddles ... as I never use them.
Old Jan 12, 2010 | 03:06 AM
Antpwny's Avatar
If your foot is into it (flooring it) then you would stay in 4th until you wanted to cruise/settle (5th).
Old Jan 12, 2010 | 03:49 PM
xorbe's Avatar
Actually no it stays in 3rd at WOT unless you're over 90 mph ... I guess no one else has encountered this, oh well.
Imagine cruising down the freeway, and the car seems stuck in 4th for no good reason.
Old Jan 12, 2010 | 05:17 PM
keepitpg's Avatar
i love college
the only reason i know for it to do that is if you touched the paddle.. if not, then idk what it is. good luck.
JerryHughes
Mar 25, 2021 08:42 PM
BigRedWeather
Jul 18, 2016 01:43 PM
mh1361
Apr 15, 2016 09:32 PM
dc9mm
Feb 5, 2015 05:28 AM
dduerr
Mar 5, 2011 05:34 AM
