Rear Seat ! curse!
Old Jan 31, 2010 | 10:23 AM
ingress's Avatar
Rear Seat ! curse!
I have 07
my Rear 40 seat the latch is wonky on it
i pull the latch, it comes up but the seat doesn't disengage
almost like a spring or something is missing, it happened about 6 months ago as well but the service shop fixed it , and said it was super simple if it happens gain just read the manual , there is nothing in the manual!!
Old Jan 31, 2010 | 01:49 PM
secondspassed's Avatar
they probably were talking about the service manual.
http://hondafitjazz.com/manual.htm
you can find drawings of that part there and try to figure it out.
Old Feb 12, 2010 | 11:44 AM
Fit4Trav's Avatar
Mine did this as well. Just take it to the dealership its probably just the latch being loose
Old Feb 12, 2010 | 12:56 PM
OneStopCustoms's Avatar
Originally Posted by ingress
I have 07
You can fix it yourself... One time the seat belt got caught on the latch, i pulled the plastic latch to release and bring down the seat and ended up "breaking" it. Took the seat apart and there's a plastic piece that holds on to the metal hanger, you have to put the plastic piece back on, its very small do not lose it. Once on, then you have to lift the other plastic piece and connect both lol. Then the plastic latch will work perfectly.
caroling
May 29, 2021 03:21 AM
Scala
Jan 29, 2017 08:52 AM
thasniperwolf
Feb 23, 2014 07:06 PM
jjgori
Jun 15, 2008 10:50 PM
Etrsi_645
Jul 24, 2007 01:53 PM
