Fluctuations in rpm Help me!!
Old Feb 10, 2010 | 06:56 PM
GMejia's Avatar
Unhappy Fluctuations in rpm Help me!!
Hello to all from the Dominican Republic! I have a problem of stability in the rpm ... When I drive at constant speed I can see and feel the rpm going up for example: from 1500 to 2000 and again falls to 1500 and again without me this accelerating or decelerating on flat roads and without a speed increase. I have a 2002 fit i-DSI engine, with all services updated (motor oil, cvt oil, spark plugs, belts, etc.). And shows no failure when you connect the diagnostic computer (OBD-II) that will may be happening to me fit? sorry my English is not very good.
Old Feb 10, 2010 | 07:01 PM
gimme's Avatar
Master FitFreaker
kinda sounds like an auto transmission slipping.
Old Feb 10, 2010 | 07:10 PM
GMejia's Avatar
Thank you for your quick response! may be failure of the cvt ... but I can do? can be repaired?
Old Feb 10, 2010 | 07:14 PM
gimme's Avatar
Master FitFreaker
just wait a bit for other responses. there are a lot of people on here with good advice so let's see what others may think.
Old Feb 10, 2010 | 08:28 PM
GMejia's Avatar
I read the owner's manual and now I suspect the speed sensor cvt ...
Old Feb 14, 2010 | 02:12 PM
hogwylde's Avatar
No supe que el Fit venia con CVT......
Old Feb 15, 2010 | 10:29 AM
GMejia's Avatar
The fit 2002 i-DSI has a continuously variable transmission (CVT). My problem with the changes in the rpm still persists.
Old Feb 15, 2010 | 11:22 AM
crash001's Avatar
Check ur cvt if not take it to a tranny shop if it gets worse how many miles do u have on it also do u feel any lose of power
Old Feb 15, 2010 | 10:24 PM
GMejia's Avatar
take the car service center certificate, you may find what the fault ... but also may charge me a lot. Since you find the problem let them know.
Myxalplyx
Mar 12, 2016 03:19 PM
Myxalplyx
Dec 6, 2015 07:36 PM
mike410b
Jan 29, 2015 07:01 AM
jonno86
Mar 31, 2011 12:06 PM
akrams
Apr 16, 2006 09:55 AM
