skunk2 short shifter help
Old Feb 25, 2010 | 02:36 PM
m-man@sbcglobal.net's Avatar
Hey how do you get that white 'cup' off the end of the stock shifter
Old Feb 25, 2010 | 02:54 PM
Tofuman's Avatar
Use some pliers. Don't damage it though. You can heat it up with a heat gun/hair dryer or hot water to expand/soften the plastic a little which could make it easier. Be sure to put fresh lithium grease on it when re-installing it.
Old Feb 26, 2010 | 11:18 AM
GD3_Wagoon's Avatar
you can also take the closed end of a hand wrench that fits around the plastic cup then work it off slowly.
Old Feb 26, 2010 | 12:23 PM
gimme's Avatar
Master FitFreaker
x2 on that. I actually dipped mine in some super hot water to soften it up.
Old Feb 26, 2010 | 12:24 PM
TurboManGT's Avatar
Yeah hot water worked for me too
Old Feb 26, 2010 | 08:19 PM
Tork's Avatar
I used 2 open end wrenches just larger than the metal shaft on my ge pried one against the other, very easy that way. My gd one I struggled a bit with a different method
pearl
May 24, 2014 07:31 PM
sikbrik
Aug 24, 2008 02:32 PM
ascGD3
Jul 11, 2008 01:31 PM
Skunk2TS
Aug 28, 2007 10:11 PM
