Anyone know which fuse controls the immobilizer
Old Mar 22, 2010 | 08:51 PM
hondafitblue's Avatar
I have an 07 honda fit sport automatic and for some reason the honda diagnostic tool is not communicating with immobilizer of the car so i cant get a second key programmed.
I would like to know which fuse controls the immoblizer maybe thats the first thing i need to check...
second where is the immobilizer located to see if there is any plugs disconneted.
other than that i can't think of why this is happening... please advise...
Old Mar 22, 2010 | 09:58 PM
Kishore's Avatar
Immobilizer control unit-receiver is in between the ignition and the dash
i.e. in front of the ignition. Hope this is clear
Old Mar 22, 2010 | 10:06 PM
Kishore's Avatar
Fuse to Components Index
Under-hood Fuse/Relay Box
Fuse Amps Component{s) or Circuit{s) Protected
Number
1 80A Batterv. Power distribution
2 60A EPS control unit
3 50A lenition switch
4 30A ABS modulator-control unit
5 40A Blower motor
6 40A No. 14 No. 15 No. 16 No. 17 No. 28 No. 29 fuses (in the under-dash fuse/relav box)
30A No. 18 No. 21 fuses (in the under-dash fuse/relav box)
8 10A Keyless receiver unit, Gauge control module, Security control unit, Immobilizer control unit-receiver, Audio unit,
Imoes unit ('08 model)
9 30A No. 22, No. 23 fuse (in the under-dash fuse/relay box)
10 30A Radiator fan motor
11 30A
NC condenser fan motor NC comoressor clutch
12 20A Rieht headliaht
13 20A Left headlight High beam indicator
14 10A Gauge control module (turn signal/hazard circuit)
15 30A ABS modulator-control unit
16 15A Horn relav. Horn ECM/PCM Brake Iiahts Hiah mount brake light
Unlikey Fuse F8 is blown. See list above
LarryS
Jun 24, 2016 03:29 PM
SilverEX15
Jul 30, 2015 03:30 PM
oneder101
Jun 15, 2015 05:03 AM
eCity Fit
Oct 18, 2014 10:44 AM
Gabybeba
Jun 11, 2013 05:07 AM
