A hissing sound when turning the car off
Old Jun 3, 2010 | 10:43 AM
einstein77's Avatar
I had the exact sound you describe everytime I shut down both my Dodge Neons. It may be related or not. Mine turned out to be the radiator fluid moving from the reservoir to the radiator as the engine cooled.
Old Aug 12, 2010 | 01:10 PM
viperjh16's Avatar
air pockit in coolent system add more
Old Aug 12, 2010 | 01:39 PM
HOLY FIT!!'s Avatar
dead thread, it was answered in the second post, its the A/C, and its not a problem
Old Aug 12, 2010 | 04:44 PM
Black01's Avatar
Originally Posted by S14b
I think it is an angry cat in or around your car. INspect for angry cats.
Are you sure? I went to check on mine but I did not see the angry cat.
Old Aug 15, 2010 | 09:24 PM
cakacon's Avatar
I just got my 08 first gen fit, and it does the same thing. I got 45 k on mine, and also I noticed the coolant tank was empty, and is very hard to get to, to put any in... I was thinking the noise was the coolant draining back into somewhere too like that other person said, I do not think it is an issue though.
Old Aug 18, 2010 | 03:25 PM
Remedi's Avatar
I heard the same sound time when I had an 03 Base Acura RSX. It all started after installing an aftermarket intake.
Old Aug 19, 2010 | 11:28 AM
z06dustin's Avatar
I had the same problem a while back, figured it was just the radiator releasing pressure or something. Later, when I was changing oil, I found these....
OMFG SNAKES ON A FIT!!!!!one!!!!
Old Aug 20, 2010 | 11:50 AM
mahout's Avatar
Originally Posted by ftlmatt
i have a 2008 Honda Fit Sport A/T with 21,000 miles on it..
i have noticed that sometimes after i turn the car off, open the hood, i hear a slight hissing noise coming from the left side of the engine, not too far down in the engine.
i have a friend who knows a lot about Honda's and he said it is nothing to worry about...
what do you guys think?
Next time you shut down, wait 30 sec open the gas cap and see if the hissing doesn't occur then (as its supposed to). If it doesn't the hissing is the fuel system releasing due to some likely minor air leak when you shut down..
Old Jan 8, 2016 | 08:19 PM
Tom Leland's Avatar
Hissing
Heard hissing tonight -- both while running and after turned off. Seems generally
coming from left side, not far from driver's seat -- under steering column, maybe a bit to left of that.
Did not run A/C at all. No idea what it is, but it's definitely a new sound.
This is an '07 Fit with about 85k miles.
Thanks for any thoughts.
Old Jan 9, 2016 | 02:18 AM
CuTeBoi's Avatar
I'd be worried..... :|
geepondy
Jan 20, 2018 11:06 AM
blazej
Feb 24, 2016 07:37 PM
arealitystudios
Nov 26, 2012 04:49 PM
Drewski
Oct 6, 2008 02:08 AM
coldstorage5
Jul 31, 2006 10:29 PM
