compression pump kills my fuse
Old Apr 23, 2010 | 02:11 AM
kernel.panic's Avatar
Hi guys. I was given a gift the compression pump on my birthday.
So it pumped my wheels several times successfully.
But it came a moment when pump started killing my cigarette lighter fuses.
I can't understand what might be wrong, I've bought ten 15A fuses and change them very often.
Can I put the fuse which has greater current strength, will it help me ?
I drive Honda Fit '03, 1.3 CVT, GD1
Thank You.
Old Apr 23, 2010 | 03:21 AM
HONDAMATIC's Avatar
do NOT put a larger fuse you may burn out other things like wiring, the pump may be faulty
Old Apr 23, 2010 | 04:19 AM
HONDAMATIC, Thank You very much. I am not strong in electricity
Old Apr 23, 2010 | 09:00 AM
NDA's Avatar
NDA
Thank You.
I use myself 20A and all ok.
Old Apr 26, 2010 | 12:57 AM
I've heard that compressor pumps burn the fuses very often. Did somebody deal with this problem ?
Old May 1, 2010 | 09:08 PM
Perrenoud Fit's Avatar
Exclamation
Are ya talking about an air compressor? And what are you using that for all the time if I may ask? A raft ? the small air compressors for cars are used in case the tire is low on your car and then stored, if your using this A/C often, well they're not reccomended for contiuios use. The compressor maybe getting worn abit and is needing more amperage from the lighter plug-in than be4
Do Not use a fuse that's larger than the original could= humm....what's that smell, 'O No Fire, Fire!!
Old May 1, 2010 | 09:42 PM
BandAidBob's Avatar
hey guys, i have delt with this a million times. i used to be a technician a Darrell Waltrip Honda an some phone chargers an larger electronics pulling more amps will blow the radio/accessories fuse sometimes.. they just weren t engineered to provide that much power.. so the fix- don t use that compressor
Old May 5, 2010 | 05:24 AM
Thank you for advices, I will put my 15A fuse back instead of 20A.
Certainly, compressor does work, really pities it.
seth8288
Jun 27, 2017 07:14 AM
SilverEX15
Jul 30, 2015 03:30 PM
oneder101
Jun 15, 2015 05:03 AM
cph81
Jul 9, 2012 12:20 PM
MIAMIFIT
Dec 11, 2010 05:28 PM
