Flickering lights
Old Sep 12, 2010 | 11:04 PM
Ciggy's Avatar
Flickering lights
I'm having a problems with all of my electronics flickering... hid headlights led foot lights led dome light dash lighting. None of the flickering is to the beat of my bass. Just random low high over and over when I'm driving doesn't happen when I'm stopped in neutral or park.
I have the independent fog lights done, led foot lighting and a 4 way ac adapter on two separate add-a-fuse. I have a 500w amp and one twelve inch sub.
Im asking for help figuring out what the problem is. Also will a capacitor help with this problem???
Thank you!!!!!!!
Old Sep 13, 2010 | 09:50 AM
Ciggy's Avatar
Could i need a new battery or alternator?
Old Sep 13, 2010 | 10:28 AM
Fat Ping Cat's Avatar
your headlights and system killed your alternator... not under warranty.
Old Sep 13, 2010 | 10:49 AM
z06dustin's Avatar
pry the alternator off and take it to napa or discount, they can test it.
i've bought high output alts for small block chevy's before, not sure they make them for the fit application.... but you're pulling some serious juice, you may want to consider a bigger alternator along with a seperate main bus, connected right off the alt, for all your accessories.
edit: re: capacitor. in an AC system a cap boosts voltage, but in a DC system all it does is provide a source of energy to provide temporary coulombs when needed (think bass hits). if you're running a constant draw (HID lights, a hotplate off that 4 way ac adapter) then a cap won't help you much if any.
Old Sep 13, 2010 | 11:07 AM
Ciggy's Avatar
Ok I dont know much about the alternator i can not even point it out. I understand it's not under warranty not to big of a deal. I would like to get a higher output alternator. Some of these guys are running crazy amounts of subs and amps does anyone have insight on a bigger/more power alternator?
Ok so a capacitor is out? Will charging the battery using a charger help if I do it at night until I get this problem fixed?
Old Sep 13, 2010 | 11:20 AM
Ciggy's Avatar
Found a few threads and someone said Iraggi Alternators made a HO for the 07-08 but for the life of me I can not find it.
Old Sep 13, 2010 | 11:36 AM
Ciggy's Avatar
I emailed powerbastards.com and received this reply. Does anyone with more knowledge think I'll be able to get this to fit?
Hello and thanks for contacting us. I would recommend our Fitzall 220+AMP alternator for your vehicle. We have these in stock and they carry a one year no questions asked warranty. If you order before 3PM EST M-F we can ship these same day. Don’t forget to check out our big gauge wiring kits with 250AMP fuse that would compliment your new alternator. Here is the direct link to purchase the alternator:
Fitzall-220 - 220AMP Alternator for Imports and Domestics | PowerBastards.com
Please read the details of this product, modifications to your vehicle will be necessary. This is a universal fitting alternator that is offered for this application because a high output direct fit is not available. Thanks so much,
Mike Savino
www.PowerBastards.com
High Amp Alternators Made in the USA!
Toll Free: (877) 261-2472
mike@PowerBastards.com
Old Sep 13, 2010 | 06:40 PM
Ciggy's Avatar
any one else have any insight?????????
Old Sep 13, 2010 | 07:56 PM
grtpumpkin's Avatar
Try also Mean Green Alternators I understand they do all kinds of import applications. 220 amps!! Sweet Jesus that sucker could power a small town!
Cody Richter
Feb 21, 2016 03:37 PM
Ciggy
Jan 30, 2013 10:00 AM
pokems23
Sep 15, 2012 12:29 AM
Wes2theG
Sep 29, 2011 11:48 AM
crudy1
Dec 17, 2010 07:10 PM
