HID golden yellow 3000k bulbs finally!
Old Dec 24, 2010 | 06:32 AM
vinnymac's Avatar
Thumbs up HID golden yellow 3000k bulbs finally!
Goldenyellowhidfogs003.jpg?t=1293346113Goldenyellowhidfogs007.jpg?t=1293189977The antagonizing wait for my replacement golden yellow hid bulbs have arrived. I have installed the vinyl overlays already because I still had my 6000k white fogs in, with those the yellow fogs were more of a whitish yellow than what I desired. Today I switched them with the new golden yellow hids 3000k, I was told that I could remove the vinyl and still get the color that I wanted with just the bulbs only. However, I left it on and installed the y/golden hids anyway and I found that the color is a lot more vibrant and shows more details of objects on the roadway. The application was a simple plug and play but with the same wattage. And yes they are waterproof and shock proof!Goldenyellowhidfogs002.jpg?t=1293188909Goldenyellowhidfogs015.jpg?t=1293188909
Old Dec 24, 2010 | 08:36 PM
808FitToGo's Avatar
Where did you mount the ballasts for the HID? I am thinking about installing HID for my fog light but not sure where to mount the ballast. Also, where brand HID do you have? Thanks. Alex
Old Dec 24, 2010 | 09:43 PM
sh00k's Avatar
Vinny, I think i saw you at wallmart couple days ago. I was the one reversin next to you when you was leavin. Fogs lookin clean, whered you the overlays? I got yellow fogs but it needs more yellow.
Old Dec 24, 2010 | 10:32 PM
vinnymac's Avatar
I got some...jus' let me know where and when and it's yours ma'man!
Old Dec 24, 2010 | 10:39 PM
vinnymac's Avatar
I mounted them behind the wheel well cover against the sub-frame. They are waterproof slimline's from HIDWORLDS. Have had absolutely nadda' single issue wit'um yet. Jus' let me know if you want the link.
Aloha!
Old Dec 24, 2010 | 10:42 PM
sh00k's Avatar
for free? i stay maui right now, i let you know when i back.
Old Dec 24, 2010 | 10:48 PM
vinnymac's Avatar
Of course Brah..for free!! Lemme know wen u back.
Old Dec 25, 2010 | 04:47 AM
LaoSiFu's Avatar
Where did you get the Brembo? I never knew they made them for the Fit. Was there a rear kit for it?
~Robert
Old Dec 25, 2010 | 04:58 AM
kelsodeez's Avatar
UNBANABLE
~Robert
https://www.fitfreak.net/forums/fit-...o-bbk-gd3.html
Brembo Big Brake Kits for your 1996 ACURA INTEGRA Except Type R Models - TopBrakes.com - Your source for Big Brake Kits
Old Dec 25, 2010 | 06:19 AM
sh00k's Avatar
shooots! thanks bruh! i'll let you know for sure!
Old Dec 25, 2010 | 12:20 PM
Rampage289's Avatar
Aloha!
looking great whats the link to the site of where you purchased them Merry Christmas
Old Dec 25, 2010 | 08:44 PM
vinnymac's Avatar
Also, lemme know if you are interested in the tint for the foggies as well...it's the ''real deal'', won't melt to your lenses or give you that false yellow look. Some say the tint with the hid golden yellow's will cause a greening effect...well not with these!
Old Dec 25, 2010 | 09:34 PM
Rampage289's Avatar
I am interested with the tint as well
Old Dec 25, 2010 | 10:20 PM
vinnymac's Avatar
I like keep'n it simple!!
I simply jacked my front up so I could sit down and apply the tint without removing or unscrewing anything. If you cut your oval (tint) a little larger than your opening ( lens ), then the edges can be pressed behind the housing while you are installing with a credit card. I simply cut 1/4 of an old card and used that for the outer edges because of the small area that you'll have to work in. You can use the bigger portion of the card to work your way out from the center. PM'n ya!
Vinny
xonexlifex
Jul 15, 2010 04:04 PM
cKranez
Apr 23, 2009 07:58 PM
Canadian_R32
14
Mar 13, 2009 02:43 AM
marcryan27
17
May 25, 2008 10:49 PM
Fit of RAGE
Mar 9, 2008 11:58 AM
