Coil Pack Replacements
Old Sep 25, 2021 | 11:52 AM
  #41
hill8570's Avatar
Originally Posted by ChunkE
Cleaned the EGR valve as I was replacing the AC coil, apparently that's not the problem either. Still low idle about 800 on cold start and dying multiple times if not warmed up. Am getting much better gas mileage since going to the Denso coils and plugs which is nice. Haven't had a chance to run my OBII reader....
Yeah, 800 is way low for cold start. Sounds like an ECT issue, but not a classic dead one (which would throw a code, light up the CEL, and have the engine running rich all the time). Does the "cold" light come on at all? If your obd reader is up to it, for sure see what engine temperature is reading after an overnight sit.
Old Sep 26, 2021 | 05:46 PM
  #42
derykisonder's Avatar
Weird that you still have problems. Are you sure they did the valve adjustment correctly? If it's not tight enough or too tight it'll cause problems. The symptoms of low idle and the car dying if not warmed up is valve adjustment signs from what I experienced.
Old Jun 4, 2024 | 12:14 PM
  #43
DW0422's Avatar
did you ever find the solution?
Old Jun 4, 2024 | 12:28 PM
  #44
Jake Fowler's Avatar
Valve adjustment. Definitively was the culprit and probably your solution.
Old Jun 4, 2024 | 12:56 PM
  #45
DW0422's Avatar
Thanks so much for the quick response that’s great news!
JCLW
Aug 14, 2023 04:41 AM
Hondarian
May 18, 2017 03:58 AM
Mtwalenciak
Dec 23, 2014 10:04 AM
RomeoJunior
Oct 20, 2014 03:38 PM
dtgrosse
Jul 17, 2014 01:04 PM
