Noise from front passenger cabin at >70mph
Old Sep 1, 2011 | 07:20 PM
ueto's Avatar
Hi, I am new to this place, bear with me if any silly questions. I purchase a used 2005 honda jazz 1.2 S(fit) MT with 70k mileage done. The car has some kind of vibration noise come from front passenger cabin when I drive at the motorway. Noise get louder when accelerating. Is that normal for mini-car like fit?
Thanks
Old Sep 1, 2011 | 08:31 PM
Texas Coyote's Avatar
A small engine has to rev up higher than a larger one to accelerate or maintain high speeds and is going to be louder... If you are feeling vibration it could be related to a drive train or wheel/tire problem.. Is it something that you notice at speeds lower than 70 or just when the engine is revving at 3500 RPM or higher?
Old Sep 1, 2011 | 10:07 PM
Krimson_Cardnal's Avatar
If you feel it in the steering wheel or your butt - like Coyote said.
Vibration noise - if you feel it in your ears, possibly some combination of windows being open can do that at speed.
Old Sep 1, 2011 | 10:39 PM
I had to spend 6 days on a cardiac ICU because I lowered my rear windows at 70 MPH while wearing a heart monitor.... I drove to the VA Hospital 130 miles from home and was fitted with the monitor that I returned with the next day I didn't know I was supposed to wait to learn if I could leave and went home where I was told by my wife that I had to return because I had had a heart attack... The monitor said my pulse had increased to 180 beats per minute at about the same time I had lowered the rear windows to let out cigarette smoke the day before... I had been in bed for 6 days and through all kinds of stress testing before I figured it out when they told me at what time my event had occurred... I decided that I had best not say anything about the window thing to the doctors.
Old Sep 2, 2011 | 01:21 PM
ueto's Avatar
i did not noticed the sound at lower than 70mph. There are no physical vibration, therefore I also suspect it may cause by wind as it only happen in motorway. The sound like a coin dropped somewhere in the car and it definitely come from front passenger cabin side. The car just take a full service from a local garage and they only did a wheel alignment.
Old Sep 2, 2011 | 01:59 PM
Subie's Avatar
Doesn't sound like wind turbulence. Maybe something (object - paper, metal, plastic) stuck in your vent tubes? I would do a physical walk around/visual inspection around the intakes (cowling, vent/filter areas, vent blades) for anything loose or don't belong. Just my guess. Good luck!
Old Sep 2, 2011 | 03:05 PM
It could be that there is something like a loose plastic panel or one of the most common gripes we see on this forum, dash vibration... If that is the problem you can use round foam backing rod from a building supply store by pushing it into the space between the front of the dash and the windscreen....Round Closed Cell Backer Rod - Backer Rod Foam Insulation
Old Sep 2, 2011 | 03:17 PM
ueto's Avatar
Sound like the possible reason, as I heard it is coming from some where between the wind screen and front of dash. Will give a try, thanks.
Old Sep 3, 2011 | 06:15 AM
macbuddy's Avatar
Thanks
I don't know if this is the answer to your problem, but have you tried toggling the "fresh air/recirculated air" lever on your Fit? If the lever is not completely pushed "home" in either direction, you may experience wind noise from the HVAC vent flap not completely sealing. I discovered that this action solved the problem in my friend's '07 GD3.
Another place to check is the recirculation intake. I once had a plastic bag get sucked up, and it was restricting air flow.
sunnyday
Aug 5, 2017 01:51 AM
pipcorona
Jul 16, 2014 06:10 AM
geepondy2
Nov 26, 2012 05:54 PM
F0NIX
Mar 11, 2009 08:50 AM
Elias
Mar 10, 2009 11:34 PM
