Alternator/Intake Manifold
Old Feb 8, 2012 | 12:49 PM
Fieldstone's Avatar
Can anyone confirm if the intake manifold must be removed to replace the alternator?
Old Feb 10, 2012 | 11:40 PM
fit2bking's Avatar
No you do not, I think you are looking at the manual for the JAZZ, I removed mine by removing the top bracket, then from underneath with a long extension I got the bottom bolt. I did this to install the unorthodox alternator pulley.
Old Feb 20, 2012 | 03:33 PM
th0m4svu's Avatar
so you have to pull the alternator out from the bottom?
Old Feb 20, 2012 | 03:53 PM
koolkevin1107's Avatar
no u reach the bottom bolt from the bottom of the car looking upwards. Then the alternator u can wiggle it out from the top of the car. Just letting u know it is a bitch.
To make it 100% easier, yes if u remove the intake manifold it will come out easily.
Old Feb 20, 2012 | 06:31 PM
th0m4svu's Avatar
hah. alright, thanks for the tip.
i'll probably just take out the intake manifold.
i'm going to give this company another try to put in a h/o alternator from Honda Fit High Output Alternators. my amplifier drained my battery to death. i've been carrying around a jumpstart kit to start my car and finally i just took the fuse to my amp out. hopefully this alternator is strong enough to support my 1000w amp :\
Old Feb 23, 2012 | 10:24 AM
Glockbag's Avatar
I actually looked at a manual that mechanics have at NTB, and yes it requires you to remove the intake manifold, i just replaced my alternator 2 weeks ago.
http://www.flickr.com/photos/glockphoto/6923392367/http://www.flickr.com/photos/glockphoto/6923392367/ by http://www.flickr.com/people/glockphoto/, on Flickr
http://www.flickr.com/photos/glockphoto/6777286736/http://www.flickr.com/photos/glockphoto/6777286736/ by http://www.flickr.com/people/glockphoto/, on Flickr
Took me about 3 hours to do the entire job including the serpertine belt
Old Feb 23, 2012 | 12:31 PM
th0m4svu's Avatar
sweet. how many amps is the new one you bought? 80/90?
Old Feb 23, 2012 | 04:01 PM
Glockbag's Avatar
Its 80 amp
Old Nov 25, 2013 | 05:17 PM
hypergd3's Avatar
It's easier to just take off egr valve then unbolt the egr studs... Took me about 15mins to pull out the alternator....
Old Nov 25, 2013 | 08:01 PM
Jack stands's Avatar
Old Nov 25, 2013 | 11:19 PM
MNfit's Avatar
I looks like its one of those cases where you dont NEED to remove the intake manifold but doing so makes the job so much easier.
Old Nov 26, 2013 | 02:10 AM
^Agreed. I replaced my alternator a couple weeks ago using the method shown in the video. Getting to that lower bolt on the alternator was a huge PITA. Hell, any kind of work in a cramped engine bay like that is a PITA.
Old Nov 26, 2013 | 09:32 PM
Mynodha's Avatar
It's not too bad if you use the u-joint socket. I use a deep socket 12mm and the u-joint. Then I use two extensions to loosen the bottom bolt without going under the car.
Old Dec 16, 2013 | 09:48 PM
mikelowell915's Avatar
If anyone is interested I have a PDF doc with a service manual for 2007 USDM email me and I will gladly send it to you via email michaellowell915@gmail.com, there are tricks to pulling the alternator quicker but there is only one "Honda way"
Old Jan 5, 2014 | 09:01 PM
wgolfguy's Avatar
MikeDD969
Aug 30, 2018 11:56 AM
deevergote
Dec 4, 2015 07:52 AM
p1driftfiend
May 8, 2013 11:35 AM
alf74
Jul 24, 2008 01:30 PM
tonyrace_41
Jun 21, 2006 09:55 AM
