purchasing a high mileage FIT
Old Nov 2, 2012 | 07:30 PM
ilretep's Avatar
considering purchasing a high mileage fit. has 157k miles. MY:'07. 5SPD Manual. Base Model. $5500. KBB rates it around $4300 for great condition and $4800 for excellent..but considering the car that high miles, i would assume it'd only be in great condition. Car is all stock. Whats everyone's opinion?
Old Nov 2, 2012 | 08:32 PM
doctordoom's Avatar
Supervillain
Need more info and pictures for an opinion. But 157k miles is pretty high.
Old Nov 2, 2012 | 08:38 PM
DaveInWoodland's Avatar
Or even just "Good". Personally while I believe the Fit is one dependable vehicle I may personally shy away for one with that many miles.
Old Nov 2, 2012 | 08:40 PM
08purplefit's Avatar
Get a carfax on the car
Old Nov 3, 2012 | 12:57 AM
ilretep's Avatar
Black Honda fit custom
say, the car is clean. what would you pay? idc if its high miles. could get a new engine on ebay and replace it for cheap.
Old Nov 3, 2012 | 01:02 AM
Type 100's Avatar
Looks good if it's all highway miles. A complete service history should be the only thing you look for.
Old Nov 4, 2012 | 08:02 PM
ilretep's Avatar
cool. just wanted some feedback. any additional feedbacks would help.
Old Nov 5, 2012 | 11:49 PM
ilretep's Avatar
what are some known problems the fit has...that i should look out for?
Old Nov 6, 2012 | 08:34 AM
Type 100's Avatar
Fits have notoriously thin paint, so you'll want to look out for rust spots or paint chips, especially at the door sills.
There's a thread floating around about water leakage at the doors into the rear passenger footwell, too. A few of us did some investigating and found that the vapor seal inside the doors failed over time. It affects a number of our cars, but my impression is it's not a widespread problem, at least judging from the buzz on this forum.
You'll also want to make sure the rear suspension is still aligned because you simply can't adjust it via wheel alignment. All it is, is an H-shaped torsion beam dead axle. If it's bent out of shape and misaligned, you'll have to replace the whole thing.
Apart from that...I think that's it, really. Good luck!
Old Nov 6, 2012 | 11:26 AM
CTCT's Avatar
As previously stated, get a Carfax or similar. There's one out there that costs $1 per report. Ask if you can do a compression check. Pull out the blue fuel relay under driver's side dashboard, pull out the spark plugs, run the compression test. Spec is 142 psi min with 28 psi max deviation between cylinders.
Old Nov 6, 2012 | 02:05 PM
ilretep's Avatar
awesome. so ran a car fax, and car seems to have been serviced regularly. 3 owners.
first owner was a loan/lien from 0miles - 25,723miles.
second owner were the parents. they had it from 25,723 - 135,000
third owner was the son. he had it from 135,000 - 156,xxx (current)
but the car fax, however, shows this:
12/29/2011 135,000 Illinois
Motor Vehicle Dept.
Farmer City, IL
Title #X1363693155 New owner reported
EXCEEDS MECHANICAL LIMITS TITLE ISSUED
Vehicle color noted as Black
CARFAX Advisor™
An EML title is issued when the owner discloses an odometer rollover to a DMV. Rollovers occur on vehicles with 5-digit odometers that go from 99,999 to 00,000 every 100,000 miles.
Mileage reported after this reading is potentially unreliable.
06/25/2012 Illinois
Motor Vehicle Dept.
Farmer City, IL Registration issued or renewed
Old Nov 6, 2012 | 02:10 PM
raytseng's Avatar
that note doesn't make particular sense-all new cars have 6-digits.
My guess is when they filled out the transfer forms they just checked the wrong box, or filled in a section they didn't need to.
I wouldn't worry about the carfax report, but I wouldn't put much faith into them either. There are many examples of potential car problems that carfax has no way of knowing about.
Old Nov 6, 2012 | 02:20 PM
I'd definitely have bought that over my car. Why pay more for a car that has likely not been as well maintained? Also, high way miles are much easier on a car than stop/go.
Old Nov 6, 2012 | 05:30 PM
ilretep's Avatar
awesome! yeah, the only issue is its a 2 hour drive out to the guy. and my main concerns with the car are just the body and paint.
Old Nov 7, 2012 | 05:57 AM
Type 100's Avatar
Sounds like none of the bugbears I mentioned apply to this Fit apart from the paint. Good luck with the deal and keep us posted
marklj
Jul 24, 2024 08:24 AM
big Fit
Dec 26, 2023 07:03 PM
j2x
Sep 27, 2014 11:17 PM
hansclap
Jul 6, 2012 10:57 PM
nnyfit
Jul 24, 2007 11:56 AM
