2007 Jazz (fit) with air con query...
Old Dec 8, 2012 | 04:32 PM
Red_H's Avatar
Hi all,
First post...
Got a 2007 Jazz with an air-con issue. Done loads of searching but can't seem to find a
With it set to '16', the temperature of the air coming out of the vents is around 20 degrees. Set it to "Lo" and it drops massively to about 8-10 degrees (what I would expect).
So basically, the system isn't behaving. Is there a mechanical 'gate' which mixes hot and cold air which could be sticking somewhere in its travel, or is there a thermostat somewhere.
Could the temperature select unit in the dash be at fault?
Advice gratefully received.
Fit22
Sep 7, 2018 09:01 PM
lknbigfish
Oct 29, 2014 10:16 PM
HondaFan2014
Apr 29, 2014 12:30 PM
cabingirl
Dec 13, 2009 04:00 PM
