Is there a brake issue after service at Honda garage?
Old Dec 10, 2012 | 05:45 AM
hakko's Avatar
Hi FitFreak readers!
Apologies if this is in the wrong place.
I've just had my Hondja Jazz 2006 (which I bought a few weeks ago), serviced at Honda in London, UK. This was a full service, including automatic gear oil change.
The brakes feel less "tight" now. Before they were more sensitive, and now you have to press down more.
Is this a case of the brakes were too "tight" and are now normal, or did they forget to do something.
I'd be grateful for some feedback here before I call the Honda dealership.
Old Dec 10, 2012 | 09:34 AM
DrewE's Avatar
It's normal for brake feel to change a little bit over time (and rather suddenly if they are serviced), but most commonly it would get firmer after service, not less firm. If you're worried, I'd call them up, or maybe bring the car back and have someone at the dealership take it for a test drive to see what they think.
Was brake work part of the service they did?
Old Dec 10, 2012 | 10:41 AM
hakko's Avatar
Level 4 service, the full whack. Car is 69,000 miles and 7 years old when I bought it.
I've got 3 months warranty with the seller, so to check for potential problems I gave it a full service, which according to the schedule it needed.
Service Schedule | Honda Owners | Cars | Honda (UK)
Old Dec 10, 2012 | 03:02 PM
Doug Just Doug's Avatar
If replacing the brake fluid was part of the service, you may need to have the system re-bled.
Old Dec 10, 2012 | 03:31 PM
DaveFL's Avatar
According to level 4, they looked at pads, calipers and drums, changed fluid, brakes needed bleeding as they have to to get new fluid to the wheel cylinders and then should have road tested. If air was still in system technician would have bled brakes again. Might show on tech's writeup. If previous owner over used brakes it would have triggered a sell that new owner a new set, to maximize the profit of the visit.;-) at least that's how they do business in this country.
Old Dec 10, 2012 | 07:18 PM
mahout's Avatar
Do not assume the tech would have bled the brakes a second time. He's paid for only one.
Your problem does appear to be air in the lines which will happen if the tech hurries. Take it back to the dealer and complain though I suspect he won't do anything. For free anyway.
You're best bet is a competent independent shop or learn to do it yourself - there are posts on here doing that. When properly done Fit brakes are rock hard when fully pressed.
good luck.
Old Dec 11, 2012 | 06:44 PM
Carbuff2's Avatar
If the rear brake drums were removed (and the adjusting star-wheel backed off for removal, BUT NOT RESET) you could experience a soft pedal.
If the rear shoes were replaced as part of the service, your Jazz may require several brake shoe adjustments before the entire "arc" of the shoes works as well as before. This might take several thousand miles.
I'd bring the car back to the dealer and voice your concern, in any case.
Old Dec 12, 2012 | 11:06 AM
hakko's Avatar
Thanks for the replies.
I've booked a check up back at the dealership.
Tway
Canada Fit Forums & Clubs
Aug 7, 2016 01:44 PM
RG129
Jan 3, 2016 06:14 PM
xwikedonex
Honda Fit Dealer Reviews
Mar 1, 2011 01:02 AM
tanstaafl.
Oct 19, 2010 06:41 PM
nodrogkam
15
Jun 9, 2010 04:49 PM
