Parking Brake Shoe Adjustment
Old Dec 27, 2015 | 06:12 PM
RG129's Avatar
Does anybody know more details about this service that my dealer just recommended for me? In all the years that I've driven Honda/Acura cars, they've never told me I needed a $70 parking brake adjustment.
My Fit has 23000 miles already, but I don't notice any slack or play with the parking brake handle.
Any insight would be appreciated. Thanks in advance!
Old Dec 27, 2015 | 10:16 PM
2015FITEX's Avatar
its possibly they are geniuses and have inspected the brakes and noticed one side may be grabbing more than the other, buts its possible they just want 70 dollars. its possible it needs adjustment, its possible it doesnt. if you notice NOTHING, they inspected NOTHING, i would leave it untill the brakes require service. (or inspection) just my 2 cents
1991 civic
1999 civic
2015 fit
Old Dec 27, 2015 | 11:47 PM
ezone's Avatar
You should have said 'that better be covered under warranty'. (if in warranty)
If the handbrake works as designed, nothing else is needed.
Ignore the upsell, it's just a money grab.
Old Dec 28, 2015 | 06:39 AM
Carbuff2's Avatar
I wouldn't pay $70 for this service, but adjusting the shoes (and lubricating the backing plate where the shoes rub) is a good maintenance practice.
I do it on our '07 Fit about once every two years. (Currently 130K miles) It helps the rear brakes do their share of the braking, and makes the parking brake grab better with less 'clicks' (since the entire arc of the brake contacts the drum).
I bet your other Hondas and Acuras didn't have drum brakes in the rear.
Old Dec 28, 2015 | 01:06 PM
RG129's Avatar
I think my 2012 Civic LX had rear drums and I never had to adjust the parking brake.
I usually ignore the dealer recommended services, but she laid it on thick with it being a 6MT and living in hilly San Francisco a properly functioning parking brake was essential.
Old Dec 28, 2015 | 03:12 PM
2Rismo2's Avatar
I've always left manuals in 1st gear and if parking on a hill, turn the wheel in such a way that it'll roll into the curb.
Found this thread that may help. The pics don't work for me though: https://www.fitfreak.net/forums/3rd-...nsmission.html
Doesn't look too hard, and you can save the $70
Old Dec 28, 2015 | 03:17 PM
2015FITEX's Avatar
images sadly dont work for me either, but this does seem like a good "sticky". probably the hardest part is getting the back of the console off..lol!
Old Dec 28, 2015 | 05:13 PM
stembridge's Avatar
The USDM Fit has rear drum brakes, which automatically adjust themselves whenever you back up (reverse) while applying the brakes. Drum brakes have been designed like this for decades. Your parking brake actuates the rear brakes via a separate cable system which does not self-adjust. There should be no difference between the 6MT and CVT, as the transaxle has nothing to do with the rear brakes.
As the brake shoes wear, you have to pull the parking brake handle farther up to close the ever-widening gap. The thread linked above indicates the nut for adjusting the parking brake cable tension is inside the console. I would expect it to be a simple 5-10 minute adjustment, including opening up and closing the console. The setup typically consists of two cables (one to each drum) that hook up to a yoke, with the adjustment nut on a shaft that comes through the center of the yoke. I have yet to need to adjust mine (32K miles), so I have not seen the actual Fit setup.
EDIT - I just adjusted mine, and it's exactly as I described. Took less than ten minutes, including getting tools out. I posted pics ind instructions on my mod thread. The $70 your dealer wants is probably standard minimum shop rate. They obviously make a LOT of profit if that's all they're doing.
That said, if your parking brake is getting so slack as to need tightening, I'd also be thinking about checking the wear on your rear brake shoes (which probably will require removing the drums). Let those wear down too far, and you'll be paying for a set of new drums along with your next brake job.
es
Old Jan 3, 2016 | 05:30 PM
stembridge's Avatar
As promised, I've posted a how-to with pics for adjusting the parking brake on my mod thread.
es
Old Jan 3, 2016 | 06:14 PM
Carbuff2's Avatar
Rear Brake Shoe Adjustment
Despite that fact that the rear brakes somewhat self-adjust, they definitely DO benefit from a periodic adjustment.
If you do this first you will NOT need to tighten the parking brake cable. I haven't needed to touch the cable adjustment on our '07 for 130K miles.
Procedure:
. Pull up parking brake ONE CLICK.
. Remove rear wheel (Fit a jack stand for safety!)
. Remove drum
. Adjust the star wheel to LENGTHEN it (two or three clicks, or notches). Each side turns the opposite way.
. Work some brake grease into the rear of the shoes where it touches the backing plate. Pry the shoes away from the plate with a long screwdriver, then slip a piece of paper coated on both sides with the grease, onto the 'shiny spot' A little is all you need.
. Refit the drum
. Step on the brake to center the shoes
. then spin the drum. Should be a SLIGHT drag.
. re-adjust if necessary.
. release parking brake handle. Drum should now spin almost free.
. reinstall wheel.
REPEAT ON OTHER SIDE
Let me know how it works for ya.
cooper58
Feb 6, 2018 07:22 PM
richard612
Jul 9, 2015 10:23 AM
hakko
Dec 12, 2012 11:06 AM
NewFitGuy09
Nov 22, 2011 07:13 PM
Sdogg
May 9, 2005 01:49 PM
