How do I disconnect positive terminal of battery?
Old Jan 26, 2013 | 04:31 PM
gfrobe's Avatar
Feel like a bit of an idiot asking this but I'm trying to change the battery on my '07 Fit (will be putting in a 51R) but don't understand what the extra wire is on the positive battery terminal (see picture). Do I have to disconnect both of the circled screws or does this whole thing lift off the terminal as one piece? If so, how do I get the whole thing off?
Thanks.
Old Jan 26, 2013 | 04:53 PM
MTLian's Avatar
Thanks.
Just loosen the bolt closest to the post. No need too touch the othe one. Just a warning: I did the same switch and my positive terminal is now very loose, no matter how hard I tighten the bolt. I need a battery terminal shim and I hope to god Napa carries them, I'm going Monday.
Old Jan 26, 2013 | 05:40 PM
gfrobe's Avatar
Thanks. Do you have a 2007 as well? There are a few posts on here related to that problem and if you don't want to go the shim route, some suggest gently tapping the post with a hammer or mallet as the metal is soft and it will widen. I'm a bit wary of trying that given I can't even get the clamp off
Old Jan 26, 2013 | 09:05 PM
MTLian's Avatar
I dunno if I'm game to start smacking my acid filled battery with a mallet. I'd just as easily unscrew a post and replace it with a larger post, I've seen them for sale. Another poster told me they do carry terminal shims at Walmart so I can always try there.
I also have a 2007 Honda Fit. Be aware that if you do this mod ou wil have to discard the battery cover and will have to cut of a part of the plastic base to accept the new battery.
Old Jan 26, 2013 | 09:08 PM
MTLian's Avatar
To get the positive terminal off, you really need an extension if you are to use a ratchet. The bolt size is 10mm hex
Old Jan 27, 2013 | 10:55 AM
gfrobe's Avatar
Just finished swapping the battery. Cut the tray as suggested in another thread and the battery fit fine.
I didn't need a shim on my battery as the positive post tightened just fine and holds well. I put in a Costco Kirkland 51R so if anyone else is installing that battery in an '07 Fit, I can confirm that no shim is needed.
MTLian, I assume you're putting in a different brand battery? Strange though as I figured all terminal posts for 51r would be standard and same size.
Old Jan 27, 2013 | 08:38 PM
MTLian's Avatar
Nope. I installed a Costco brand 51r which is battery #11 by their numbering system. I've tried everything and it really won't hold tight enough for me, need the shim.
erichyung
Mar 16, 2026 04:11 PM
Jensen Healy
Dec 6, 2019 02:54 PM
ChuckDustin
Mar 29, 2019 09:11 PM
hqly
Feb 6, 2013 03:43 PM
wenbellz
Nov 2, 2012 02:01 PM
