Do I need a new deck??
Old Jan 27, 2013 | 02:47 PM
hondahazard's Avatar
Hey all,
I came up on a ten inch sub and an amp. I really want to put it in the fit but I don't know if I would need a new deck to put in the sound system. Anyone have upgraded speakers in their fit? Advice?
Old Jan 27, 2013 | 04:37 PM
overlimit's Avatar
You can use a line level adapter (sometimes called a hi/low level adapter) to do add a subwoofer without upgrading your stock stereo. Basically all you do is tap into the +/- speaker wires, run them to the adapter,then run your RCA cables from your amp into it. Power the amp as usual.
Any car stereo place worth a lick should have them.
Old Jan 27, 2013 | 09:43 PM
13fit's Avatar
like above states, a converter that changes speaker signal to RCA will work. your hardest part of the job is removing the bottom bolt/screw of the radio anchor. its above the right cupholder, slightly tilted towards rear of car. I removed my center console to get to it, its a pain.
entire interior of this car is easy to remove and flexable. I just got done installing all my wiring for a 4 channel amp and subwoofer setup. power down the driver (left) side, all the RCA's, remote wire, and some zipties to keep it tidy down the right passenger side
TunaSoda
Jul 4, 2013 12:41 PM
FyrFytr
Apr 10, 2012 12:46 PM
mdsniper7
Feb 18, 2012 07:00 PM
sethne
Jun 27, 2009 03:43 PM
itfits12
Dec 18, 2007 09:35 PM
