Solenoid Circuit Problem
Old May 30, 2013 | 02:31 PM
REZI's Avatar
My 2001 Honda Fit 1.3 GD1 has lit engine check, I checked with electrical diagnostics and got the error code 21 - 01 VTEC SOL 1 (FAILURE P1253)
Can anybody advice me what should i check and how?
Thank you in advance
Old May 31, 2013 | 03:58 AM
loudbang's Avatar
First verify that your oil level in the oil pan is up to limits. (some have been caused simply by being extremely low on oil).
Next locate the solenoid right side of engine just below the engine cover on the right side (looking from in front of the car). It looks like an upside down silver 35mm film can with wires coming out of it. Disconnect and connect the connector a couple times to remove any corrosion on the pins them drive it and see if the MIL goes away.
If not remove the solenoid from the engine by removing the two bolts and clean with q tip and reinstall. Try it again.
If not replace the solenoid.
Matthew Falzon
Nov 22, 2018 07:07 AM
daleyt
Mar 15, 2016 02:34 PM
colnago
20
May 7, 2015 12:35 AM
xwikedonex
Sep 2, 2010 11:44 PM
KnifeEdge_2K1
Feb 19, 2007 01:29 AM
